Maf
Old Nov 18, 2006 | 10:39 AM
5thgenmaxima's Avatar
Maf
I have been experiencing some problems that are defiently sensor related.
Hesistation and vibration on occassion
Transmission shift points are changing
Transmission fluid pressure fluctuating causing a slip then jerk
ETC.
I know these all have to be related and I can only think of a few sensors that control the Trans and Engine.
MAF, TPS, MAP, ETC.
2000 stock MAF.
If I didn't know of the common maf problem I would lean toward TPS.
Two questions
1.) Has anyone had any TPS problems on their 5th gens?
2.)For the folks who have replaced their MAFS, did you have trans slipping and shifting problems. (Sometimes the rpms sit @ 3K and won't climb and at the same time it won't shift.....Also as stated above when I put the engine in gear during vibration it will rev for a second then jerk like the fluid pressure is low.)
Thanks in advance.
Old Nov 18, 2006 | 11:28 AM
monty31's Avatar
Have you cleaned your throttle body? If so, did you disconnect your TPS?
Old Nov 18, 2006 | 11:40 AM
No, I haven't cleaned my TB.
Old Nov 18, 2006 | 02:22 PM
mist max2000's Avatar
thats def your MAF i had the same problems, changed my maf and all went back to normal,.. change it out for 100 bucks and u will be happy,.. theres a 1000 threads on this
Old Nov 18, 2006 | 03:21 PM
Originally Posted by mist max2000
......... theres a 1000 threads on this
yea I know. Searching brings to vague of results.
Which one did you buy?? I know some people buy a different year maf. Do you have a part #? Thanks
Old Nov 18, 2006 | 03:30 PM
LA02MAX's Avatar
call up dave b (his number is in the FAQ sticky) and order the 2Y001 one...he'll know what you're talking about. Tell him you're an .org member and he'll give you a good deal <$100
Old Nov 18, 2006 | 03:31 PM
both of you thanks.
Old Nov 18, 2006 | 09:34 PM
OutMaxxed's Avatar
hey man im selling a MAF i bought from Dave B. Heres the link. Let me kno.
http://forums.maxima.org/showthread.php?t=500703
Old Nov 19, 2006 | 06:11 AM
Murphy5156's Avatar
I definitely think I should replace mine, too. Thanks for the info!
Old Nov 19, 2006 | 09:39 AM
Dan5.5's Avatar
Sorry to ask a question on your thread, but i think its better then having a million threads.
Under what warranty is the MAf covered? Is it under the 60 thousand mile warranty? Or am i out of luck and have to fork out the money ?
Old Nov 19, 2006 | 01:15 PM
Thanks for the link, but I work at a dealer locally. Hence the asking for the part #.
Whatever your powertrain coverage is.
Old Dec 4, 2006 | 01:32 PM
boxtwo's Avatar
That's not what my local dealer told me. They said sensors are covered under the 3/36... If I was given bad info, PLEASE LET ME KNOW!
Old Dec 5, 2006 | 06:32 PM
The dealer I work at has a Nisan building, but I don't work there. The line up I work on covers anything to do with the powertrain for 3/36 (5/60 starting in 06) so I can't tell you for sure.)
Look at your warranty info to be sure.
Old Dec 5, 2006 | 06:54 PM
zero2sixtyZ's Avatar
You embarrass me.
MAF is not covered under powertrain. Only 3/36.
Old Jan 3, 2007 | 06:20 PM
imchaiwala's Avatar
'Transmission shift points are changing'
- check the o2, pull it out, and give it a good cleaning
by wiping it very carefully w/ a cloth
Jerkiness can be often solved by checking the MAF, clean the airbox and screen too. do it w/ a cloth- but clean the maf w/ compressed air (w/o getting the liquid co2 on the maf)
Old Jan 3, 2007 | 09:48 PM
PAREDLINE's Avatar
I have the same issues. They started last week when I cleaned my TB. I removed the rubber hose from the air box to the TB and cleaned with aerosol gum cutter. I guess some of it sprayed onto the MAF because it hasnt been the same ever since.
Today I removed the TB, cleaned it really really well. Cleaned the IACV too. It was encrusted with carbon. I also used aerosol MAF cleaner on the MAF and some of the symptoms are gone but I still have weird shift points and it seems my high RPM torque is gone. Low RPM torque and idle is awesome now. So smooth.
I'm going to see if I can do more research on this before I change my MAF but the cleaner spray definitely helped a lot.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
