Help, 2k2 ECU removal
Old Dec 4, 2006 | 05:19 PM
Utsutsu's Avatar
Hi,
Right now I'm in the process of removing my ECU from my 2k2 Maxima.
I read the "2000-2001 ECU Removal for TS Flash" in the how to section.
http://forums.maxima.org/showthread....53#post3192153
But is listed for the 2k & 2k1 models. Will this apply as well for the 2k2??
I'm stuck on #8, I can't see the bolts holding the ECU down.
I'm gona run back outside and take another look.
1)Power/slide seats back as far as possible and lift steering column as high as possible.
2)Use 12mm socket to disconnect battery for 10mins. or more.
3)Pull/pop off black lower kick panel on PASSENGERs side of tunnel.
4)Attach wrist strap to ground screw behind/below glove box(anywhere convienient).
5)Push tab and pull black bar from left to right on ECU connector.
6)Push connector up out of the way.
7)Tuck shop rag inbetween carpet and ECU to catch the screw you will drop or else you'll need to add a magnet wand to your tools needed list.
8)Use 10mm wrench(gear type preferred) to remove 1st of 2 bolts holding ECU bracket to floor.
9)Switch to DRIVERs side and pull/pop off black lower kick panel on DRIVERs side of tunnel.
10)Attach wrist strap to ground screw.
11)Tuck shop rag inbetween carpet(probably not necessary, but just incase).
12)Unhook zip tie snap from ECU bracket with needle-nose and flat screw-driver or cut with snips if you don't care.
13)Use 10mm wrench(gear type) to remove 2nd of 2 bolts holding ECU bracket to floor.
14)Push ECU and bracket towards PASSENGER side.
15)Switch to PASSENGERs side.
16)Use 8mm socket to remove 4 bolts holding ECU to bracket.
17)Place ECU in anti-static bag and carefully package for drop&kick protection.
18)Follow TechnoSquares instructions on where/how to ship with filled out form off their website.
I'm gona take some picture soonest the camera finish charging.
Any help would be great.
Thanks.
Old Dec 4, 2006 | 05:28 PM
NmexMAX's Avatar
dot dot dot ...
I left the bracket there, just pulled it(ECU) out and left the bracket in its place.
Old Dec 4, 2006 | 05:38 PM
Utsutsu's Avatar
I saw two plastic clips,
But there are also 2 screws one on each side of the ECU.
Do I have to take the just the plastic clips, or just the screws or both?? or is there something else I'm not seeing.
Is really tight in there, makes it hard to work on there.
thanks.
Old Dec 4, 2006 | 05:50 PM
NmexMAX's Avatar
dot dot dot ...
I just took the small nuts off. I left the plastic clips on, since the clips are connected to the bracket, and I left the bracket on the car...therefore, it was not needed to remove them.(in my case)
Old Dec 4, 2006 | 05:55 PM
Utsutsu's Avatar
So I just need to take the 2 small screws on each side and thats it??
I will try again tomorrow, its getting dark and cold outside.
Old Dec 4, 2006 | 06:03 PM
NmexMAX's Avatar
dot dot dot ...
There might be some on the other end (total of 4) but it's been ahwile.
Good luck with that edeavor.
Old Dec 4, 2006 | 06:36 PM
Utsutsu's Avatar
and here I thought I was going to have it out within and hour and taken it to fedex by tonight. Hopefully I will have it out by tomorrow.
Old Dec 4, 2006 | 07:00 PM
NmexMAX's Avatar
dot dot dot ...
It's really not that hard. Took me less than 1/2 hour. Could be because I have prior experience with the A32 ECU Which is very similar if not the exact same procedure.
Old Dec 5, 2006 | 09:06 AM
Redstone's Avatar
Utsutsu You know I was going to post something about this exact same thing concerning ECU removal, but I think I just figured it all out based on the first few posts. This thred was really helpful. By the way may I ask what is wrong with your ECU? And are you planing to have it repaired or replaced? I am planning to replace mine with a new one since the after a thorough examination of the car the dealership told me I had a bad ECU. I am just shopping about for the best deal on a new one, but I am also contemplating on having them install it just in case anything goes wrong I can take it back for a free repair. After all they are gonna credit me for the diagnostic fee if I do it within 90 days, so that means I will pay nothing for the labor upon installation if I have them do it.
Old Dec 5, 2006 | 10:57 AM
Utsutsu's Avatar
Hi there,
Well there is nothing wrong with my ECU it works fine, I'm just sending it to TechnoSquare Inc. So they can do the L-SPEC upgrade. I wanted to send it as quick as possible so they can get it before the 6th, that way they canl send it back the next day after the upgrade. After the 6th I was told it will take 3 days to send it back.
http://www.technosquareinc.com/limited.htm
They are going to do:
REV limiter modification
We found that with the ECU upgrade, more power can be gained with a higher rev limiter. A 7100 RPM (stock 6600 RPM) rev limit is set to take advantage of top end horsepower, while still providing a safe protection for the motor.
Speed Limiter Removal
The stock speed limiter of 236 km/h (148 mph) has been removed.
Drive By Wire Adjustment
Throught our testing we found, the drive by wire system was program to never fully open (throttle flap) when you smash the accelerator pedal. In fact, it actually closes the closer you get to the rev limiter, by as much as 20%. This restricts air into the motor and causes HP and Torque numbers to go down. We have remapped this setup so when you go wide open throttle, the throttle flap fully opens and STAYS OPEN, increasing HP and Torque.
Old Dec 5, 2006 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
I realize you're just quoting their site, but get the facts before you post as if you're the one claiming things.
Without a modified intake manifold, your peak will still be far below this new RPM.
Like we really need that.
This has proven to be untrue.
Throttle stays open.
http://forums.maxima.org/showpost.ph...5&postcount=22
Old Dec 5, 2006 | 12:11 PM
Utsutsu's Avatar
Yes, I just quoted from their site, The reason I was sold by it. It was there are several post about here in the Org and on 350z forums that the technosquare flash actually works. Unlike the JET chip that does nothing. There were even a couple of GD going for the TS flash a while back.
Old Dec 5, 2006 | 04:04 PM
HotshotVQ35's Avatar
so the ecu upgrade is useless unless your heavily modded? seems like it, i dont drive over 150 mph, and if the higher redline without an IM dont do jack, why get it?
Old Dec 5, 2006 | 07:33 PM
Puppetmaster's Avatar
His point wasn't as to whether the reflash will work or how credible TS is, his point was that to take full advantage of the reflash, more work has to be done to the car.
Old Dec 5, 2006 | 08:11 PM
Utsutsu's Avatar
I understood what he meant, and I did not mean anything by what I said. I know I will have more work to do and I do appreciate all the help I get in the org.
Back on topic, It seems wont be sending my ECU to TS since I can not get the darn thing to come out.
I manage to get the screw out from the second pic, I can not get the one on the opposite side.
From what I can tell, I might have to disassemble the glove compartment and the Center Console to get better access to the ECU bracket.
Old Dec 5, 2006 | 09:14 PM
maxspeedse02's Avatar
Thinks he is fast
This is next on my list. I really feel like my motor is being choked up on the top end. How much are they charging you for shipping? Have you dynotuned yet? I've been told that eventhough it's the limited spec you will need to adjust the a/f. let me know how it goes
Old Dec 5, 2006 | 09:21 PM
NmexMAX's Avatar
dot dot dot ...
The TS ECU wont do anything for this problem.
Old Dec 6, 2006 | 05:01 AM
Like Nmexmax said, its not going to unrestrict your high end that significantly. The L-Spec is w/o AF because it was for people who'd rather tune themselves, which based on what I've seen, produces better results than having TS set the AFR for you.
Old Dec 6, 2006 | 05:09 AM
Utsutsu's Avatar
Right, I'm just having TS do the L-Spec and having a local shop tune it for me.
Since TS will not have my car there for them to tune, it will be hard for them to get the AFR correctly. Now if I was close to TS, I would gotten the F-Spec.
Old Dec 6, 2006 | 05:21 AM
That's exactly it, plus if and when you add/remove mods that make significant changes to AF, you don't want to have to keep sending it in to TS for updates. And this is assuming they can get the AF done right in the first place.
Old Dec 6, 2006 | 07:00 AM
Utsutsu's Avatar
The whole L-Spec w/ shipping back its $345. You just need to pay to get it there, from top of my head using fedex I believe it was $20-$25 for the normal shipping 4-5days delivery or 2 day delivery which is about $40.
I dyno my car before, when it had the Injen intake and the Greddy, but I changed them. I got a Berk Intake and a Cattman catback now and I'm just waiting for the Cattman headers to arrive. Soonest I get everything install I will have my car dyno tune here locally.
Old Dec 6, 2006 | 09:51 AM
The difference in power you're putting down between those two set-ups is almost negligible.
Btw, do you have the runfiles from your dyno? If so, could I take a look at them please?
Old Dec 6, 2006 | 10:13 AM
NmexMAX's Avatar
dot dot dot ...
Old Dec 6, 2006 | 11:05 AM
Utsutsu's Avatar
I wish I had ask for the run files, I did not know about the since that was my first time at a Dyno. I did however made a post about it, NmexMax posted in there. But when my car gets Dyno tune, I will make sure to ask for the run files.
http://forums.maxima.org/showthread.php?t=482335
Old Dec 6, 2006 | 06:35 PM
Utsutsu's Avatar
I made some progress in my quest for the ECU. I manage to get 3 screws out of 4. I might have worn out the 4th screw which is making it difficult to get it out. There is 2 screws on the driver side and 2 screws in the passenger side.
I had to take out the glove compartment and the dash underneath the steering wheel. This makes it much easier to work underneath.
I took some pics.
Old Dec 6, 2006 | 07:37 PM
NmexMAX's Avatar
dot dot dot ...
Looks like my PLX-R300 install
Old Dec 18, 2006 | 12:54 PM
Utsutsu's Avatar
I hope someone could help me, I was not able to get the ECU out. So I started to hook everything up. Connected the ECU, the glove compartment cable, and the battery in that order.
When I tried to start the car, it would just crank and it won't start.
I had everything disconnected about 5 days.
Anyone have any idea of what it could be, I never had any problems with the car before. Nissan charging me $75 to tow it to the dealrship, + whatever it is to diagnose, + labor, + what need to be fix.
Old Dec 18, 2006 | 02:48 PM
IllegalMax
its sounds like a ecu is a pain in the ***. my question is - is it even worth instaling a ecu? if so what do u get out of it? and who makes a good ecu? and also what kind of mods do u need?
Old Dec 19, 2006 | 07:51 AM
Redstone's Avatar
This is why I decided not to mess with my ECU. In addition I would hate to do all that work and pay $700 to order a new one and then find out something is wrong with the new one after installation. And the down side is there is a no return policy at the stealership for electrical parts. I am having them put mine in beacause they are also giving me a 12,000 mile warranty on the repair and I am going to make sure they print me a copy of that unless it's on the receipt so I don't get screwed later if something happens and someone else tells me there is no such pocily. I usually do most of the repairs on my car, but this I'll leave this one for the stealer.
Check to make sure all your connections are tight. If you disconnected any connectors make sure they snap back fully in place then try to start it again. Since you never succesfully got the ECU out I don't see why the car should'nt start. Good luck.
Old Dec 19, 2006 | 09:14 AM
Is the ECU harness connected perfectly with the black clip securely fastened? If that is even a little bit off, there will be no connectivity. I know this is elementary, but the first time I disconnected the ECU I didn't reconnect it right and the car didn't start either (obviously).
Old Dec 19, 2006 | 09:15 AM
Read posts #10 to 20.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
