2001 AE alarm problem
Old Dec 4, 2006 | 06:51 PM
9maxima5's Avatar
Guys my damn alarm goes off like every 45 minutes. I did a search and found out that the hood sensor might be broken but it is all good. I made sure the lights are all off and the doors are all shut but its still goin off. Any one have any ideas? Thanks
Old Dec 4, 2006 | 06:56 PM
9maxima5's Avatar
I also just checked all the sensors on the door and there all working perfectly. Anyone?
Old Dec 4, 2006 | 07:13 PM
MaximaGT-R's Avatar
I'm a Happy Man!
beats me do you have factory or aftermarket alarm?
Old Dec 4, 2006 | 07:14 PM
"Bran Da Man"'s Avatar
In what condition are your remotes? Are any of the buttons worn? The panic button may be making contact beneath the red rubber button. Where do you store your keys? If all else fails, try this link: it's at maxima.theowensfamily.com under technical bulletins
http://maxima.theowensfamily.com/tsb/NTB01-009.pdf
Hope this information is helpful.
Respectfully,
"Bran Da Man"
Old Dec 4, 2006 | 07:53 PM
9maxima5's Avatar
It's all factory and i just got the car 3 days ago from the dealer. I am goin to have them look at it asap but what do i do for the time being?
Old Dec 5, 2006 | 04:38 AM
9maxima5's Avatar
Is there any other way to disconnect the alarm besides taking off the battery terminal? I can get the alarm to stop if i take out the fuse but the lights will flash. Is there anyway to shut it all off?
Old Dec 5, 2006 | 04:42 AM
MaximaGT-R's Avatar
I'm a Happy Man!
well believe it or not there could be a low battery in the remote. have the battery changed and see what happens.
Old Dec 5, 2006 | 05:17 AM
9maxima5's Avatar
MaximaGT-R has this happened to you.
Old Dec 5, 2006 | 05:22 AM
MaximaGT-R's Avatar
I'm a Happy Man!
No never happen i had an aftermarket alarm installed right away when i got my car but my friend does alarms and ive seen people bring in there cars and its have similar problem. What i can do is call him and ask him what could cause that. i will keep you posted
Old Dec 5, 2006 | 05:33 AM
9maxima5's Avatar
Thanks bro I appreciate it.
Old Dec 5, 2006 | 06:48 AM
MaximaGT-R's Avatar
I'm a Happy Man!
I just asked my friend he said it could be the any zones that is triggering the alarm. So he suggested disconnecting the battery for about 15 to 20 minutes which should reset the factory alarm brain
Old Dec 5, 2006 | 06:50 AM
9maxima5's Avatar
K i did that for about 5 hrs so i will go back tonight and see how it goes thanks bro
Old Dec 5, 2006 | 06:51 AM
9maxima5's Avatar
I have my car parked . I am at work so i had it disconnected for about 5 hrs lastnight and about 9 hrs today . Well see how it goes after work tonight.
Old Dec 5, 2006 | 07:04 AM
MaximaGT-R's Avatar
I'm a Happy Man!
Oh aight keep me posted
Old Dec 5, 2006 | 11:56 AM
9maxima5's Avatar
Bump anyone else have any suggestions before I leave work.
Old Dec 5, 2006 | 12:50 PM
JohnWEngle's Avatar
Check the owners manual. You may be able to pull a fuse that will kill the alarm and still leave the car driveable.
Old Dec 5, 2006 | 02:11 PM
Did anyone look at the link that I recommended? Click below please.
Old Dec 6, 2006 | 03:47 AM
9maxima5's Avatar
Car was dropped off at the dealer ( I just picked it up 3 days ago) so I will find out today. Will keep posted.
Old Dec 6, 2006 | 12:02 PM
Nomad's Avatar
Your ECM unit was fried by Stealership . ECM I believe is the one that controls body electronics, correct me if I'm wrong. Try using TSB provided above. I bet it won't work. I've tried it. Same thing happenned to me when I was Attending to make LED key ring. BTW does your key ring lits on all the time? Well just go back claim that problem started after servising your max there. If they will deny that it was their fault (they deff. will) go somewhere else and have you ECM checked.
Good luck!!!
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
QueensMAX
Sep 15, 2015 04:14 AM
conansriver
Sep 11, 2015 10:26 AM
nbstriker10
Sep 4, 2015 04:26 PM
