Removing headlights in 2001 AE
Old Dec 9, 2006 | 06:26 PM
CaTalyst.X's Avatar
I purchased some HID's from a member of this forum, and Edward Lee was very generous and hooked me up with the writeup to install them, but what I don't know how to do is remove the stock headlights. The only thing I see is the top 2 bolts, is that it? I did some searching and found there might be 2 bolts near the radiator but I wasn't able to see them and I think I might have been looking in the 4th gen forum I know it will take some eh... persuasion to get them out even after the bolts are removed, I just want to make sure all of them are Any help would be much appreciated.
Old Dec 9, 2006 | 07:03 PM
707SE's Avatar
I just removed mine today. It's somewhat simple:
Remove the two bolts and for me, I began to wiggle the light left to right until the side closest to the grill loosened and came out. From there you continue to wiggle/tub on it and the corner side will come out.
Old Dec 9, 2006 | 08:08 PM
CaTalyst.X's Avatar
So its just that easy, the two top bolts, wiggle and your done? That sounds easy enough
Old Dec 10, 2006 | 12:05 AM
SoonerFan's Avatar
Cletus
just be careful not to break the tab on the bottom of the headlight
Old Dec 10, 2006 | 01:22 AM
CaTalyst.X's Avatar
I don't really care about being able to put them back in But I assume I would just pull up on it while i am wiggling to avoid snapping that off, alright ill give it a shot
Old Dec 10, 2006 | 07:57 AM
Trurida18's Avatar
hey, CaTalyst.X ive got a 2k1 maxima as well and i was wondering if you could PM me or email me that writeup on how to wire the 2k2 HID's in the 2k1 maxima's?
im thinking of just purchasing some ebay HID's for like 400 bucks
Old Dec 10, 2006 | 01:35 PM
Maxima570's Avatar
Hey I took the headlights out of my 02 when i cleared them/intalles angel eyes, and there was a third screw on the outer side (opposite the grill) that I could only access from the front of the front wheel well. It was a pain but doable. I'm not sure about the 01s, but if your having trouble with the wiggling, try that.
Also, put a towel or something on the bumper under the headlight so u wont scratch it up when u wiggle the light out
Old Dec 10, 2006 | 02:41 PM
CaTalyst.X's Avatar
More good info i wouldnt have thought to do the towel thanks, also when you put them back in..any extra clips needed? or just pop em in and the two bolts
Old Dec 10, 2006 | 03:08 PM
SoonerFan's Avatar
Cletus
the clip i was saying not to break at the bottom of the headlight actually connects to the car. the headlight clips in to it. so you dont want to break it or the new headlights wont stay in right
Old Dec 11, 2006 | 08:08 PM
CaTalyst.X's Avatar
Would it be better/safer to just remove the bumper?
Old Dec 12, 2006 | 07:07 AM
2kprlmax's Avatar
that is to much work. The clip is a white clip if you wiggle the light out and not yank on it it should not break.
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
QueensMAX
Sep 15, 2015 04:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
