Help Installing Helios HID kit
Hey
i could not find anything relevent to what im about to ask
I received my HID kit, The relay that i recieved has 4 connectors on it......One for the First Ballast, the Second for the Second Ballast, the third for the Power where i attatch to the battery terminal, hot side of course. And the last plug is a red plug that i cant seem to plug into anything except the actual H4 harness adapter that came with the kit. Now my only other issue is that this relay DOES NOT HAVE A 5TH adapter for the 2nd H4 harness adapter...
could any one give me some insight please....ill post pics if need be
thanks
thanks
yes.. it's a relay, so it only needs to catch the signal from one side of your headlights
wouldn't it be a waste of parts to run two relays? duh.
and it's not like your stock headlamp harness is gonna burn out through it, because you are, in fact, running it through a relay, which keeps all that current draw out.
yea i know its not gonna burn out, but that answers my question about the relay. The reason i asked is because on many of the diagrams on the NET, they all had Two relays or had two connectors. But hey, better safe than sorry
AND MY LAST QUESTION is.........WILL I HAVE A PROBLEM WITH OUR CARS "AUTO" headlight feature? You know where the lights cut on or off depending on the ambient light. Seeing as how the Relay has a direct connection to the Battery
thanks
i just finished installing them AND THEY WORK FINE IM JUST NOT SURE IF I HAVE MY HI BEAMS are working.... its day time and all and i guess im supposed to see the flicker, or what??
now was i supposed to switch the diode and attatch that backup reverse WIRE??????????????????
please help me
IM A TAD BIT CONFUSED AND THE DIRECTIONS DONT HELP FOR that issue
the relay that i have connected is connected to one of the headlights....CAN SOME ONE INFORM ME A BIT
ARE THE HEADLIGHTS SUPPOSED TO FLICKER LIKE MY OLD HALOGEN BULBS BETWEEN HI AND LO BEAMS
please help me
Originally Posted by Andrew
Do you have any pics? that would probably help more
nope....but i can take some tomorrow when its daylight out......what exactly did you want me to take pics of? the relay or the connectors
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
