My car doesn't burn oil, how rare is that???
Old Dec 25, 2006 | 11:22 AM
  #41
nismology's Avatar
Originally Posted by maxspeed96CT
And every car burns alittle oil if its drivin hard.
If you dnt burn oil, you prolly never get your rpms over 4 .....
Ummm...driving the car hard reduces blow-by since load pushes the rings out against the cylinder walls. High RPM/low throttle angle is what causes the most blow-by. So if driving habits indeed have anything to do with oil consumption it's the exact opposite of what you're saying.
Old Dec 25, 2006 | 11:29 AM
  #42
nismology's Avatar
Originally Posted by jeff5347
Reasons for oil burning.
-bad valve seals
- piston rings (Top ring = oil ring) lose tension and allow oil into the cylinders therefor being burnt
- Also scores in the cylinder where the ring cant get to to seal the scratches, oil then creeps up thru. Oil in the oil pan doesnt just sit there it is a tidal wave of motion such as putting an egg better in in water
Wow...
There's no evidence of valve oil seals going bad on any VQ on this site or anywhere else, regardless of mileage. And the oil control ring is NOT at the top. There are two compression rings on top, then the oil control ring and expander is at the BOTTOM. Furthermore, oil ring losing tension on a 50k motor? Man, where are you getting this stuff from? And i won't even respond to the last one.
Ok...re-read your post. If you're just brainstorming and thinking aloud about reasons for oil consumption in general then ok. But i think that the oil consumption problems on the 3.5 in particular are due to improper cylinder honing technique and/or improper break-in which results in excessive blow-by and oil vapors entering the intake tract. I've heard of oil burners losing compression so it's what makes the most sense to me.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
Samedi
Aug 13, 2015 04:05 PM
