SES light??
Old Jan 11, 2007 | 10:51 PM
asianstyle's Avatar
SES light??
Coming home from work tonight and the SES light comes on, still drives normal though. Just wondering what you guys thoughts were, going to autozone in the morning to see what kinda code I get. I have 90,000 miles on it. I just installed my berk intake about 1 week before also. with the dry apexi filter.
Old Jan 11, 2007 | 11:40 PM
artin64's Avatar
SES light??
It could be your MAF (Mas Airflow Sensor). I had some problems when i first installed my intake, if the intake is not secured properly nad its shaking, the ses light might come on. It happend to me, got the code it was the MAF i checked the MAF there was nothing wrong with it, so i secured the intake cleared the code and no more ses light till this day. this was 5 mounths ago. Ofcourse u wont be sure untill u get the actual code and see what it is. goodluck
Old Jan 12, 2007 | 03:00 AM
MaximaGT-R's Avatar
I'm a Happy Man!
could be o2 sensor.
Old Jan 12, 2007 | 04:03 AM
rad's Avatar
rad
it was o2 sensor in mine 2k2 (90k). but still having pinging issues around ~1800rpm
Old Jan 12, 2007 | 04:50 AM
maximamass's Avatar
get the code before you do anything and then look in the stickies for what the code is.
If its a 0430 is either the computer needs to be flashed or its the CAT. A 0420 is sometimes the O2 sensor but just get the code first!
Old Jan 12, 2007 | 06:44 AM
asianstyle's Avatar
thanks guys, I went to autozone this morning and I got a code P0420, which said (catalyst system efficiency bor bank 1 below threshold for the current engine operating conditions.) Is this the O2 sensor some of you are talking about? I read somewhere that I need to get my ECM reprogrammed, do you guys know anything about this or should I just take it to the dealer and let them change out whatever to get it fixed. I've got an extended warranty so price doesn't matter
Old Jan 12, 2007 | 07:49 AM
MaximaGT-R's Avatar
I'm a Happy Man!
if you have the extended warranty i believe that should cover the o2 sensor if not the ECM reprogramming should be.
Old Jan 12, 2007 | 02:58 PM
P. Samson's Avatar
I see the crankcase vent hose on the Berk intake in the photo, but I don't see the power steering Air Control hose connected? Is it connected?
Old Jan 12, 2007 | 06:46 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread.php?t=289375
Old Jan 12, 2007 | 07:52 PM
P. Samson's Avatar
If you make a change/do a mod. and then shortly after you get the SES light ON, then chances are it's related to the change or mod. In this case I believe the Berk Intake has no hose adaptor for the power steering Air Control Valve supply hose that normally is connected to the stock intake "air box". This hose supplies air into the intake downstream of the TB via the power steering Air Control Valve when you crank the steering off center, particularly when there is high vacuum at idle and at low throttle openings and this air is "seen" by the MAF and ECM and the ECM "tweaks" the fuel delivery as required to maintain the correct AF ratio. If this hose is not connected between the MAF and the TB when this air enters the intake, the MAF and ECM never "sees" it. Effectively a lean condition occurs, dumping to much O2 into the cat/s causing the P0420 to be set.
Old Jan 14, 2007 | 07:22 AM
asianstyle's Avatar
I have everything connected that there is a place for. I've got the MAF and three hoses connected. I do have a question though. I have this factory air scoop looking thing that was hooked up to the factory air box, and it has a connector/sensor pluged into it. what do I do with this connector/sensor?? You'll see it if you look at my cardomain page. it looks like a factory ram air scoop. thanks for the help guys.
Old Jan 14, 2007 | 07:26 AM
asianstyle's Avatar
it's the black plastic thing to the left of the battery, you'll see the sensor right below my oil catch can. what do I do???
Old Jan 18, 2007 | 02:07 PM
asianstyle's Avatar
hey guys,
would this code cause my car to shut off while driving b/c that's what it did today. I have a 5 speed so I started it right back up. I also reconnected my factory intake box b/c I will be taking it to the dealer tomorrow.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
