2002 Power moonroof
Old Jan 18, 2007 | 08:20 AM
fornimage's Avatar
2002 Power moonroof
Anyone had a problem where sometimes if you brake hard enough that your moonroof will automatically slide open 2 inches out of the blue? I would have slide to switch back and forth to close it. I'm thinking t could be a loose battery connection but haven't checked yet it and just wanted some opinions. Thanks.
Old Jan 19, 2007 | 09:44 AM
98sebring's Avatar
Sounds like it's possessed.
Old Jan 19, 2007 | 10:15 AM
sweetjackal82's Avatar
I have a problem with mine too...
It doesnt work at all. The "Tilt" works but the "slide" doesnt work at all. I have replaced the switch twice, that fixes the problem for a few months, then it goes out again...
Any ideas??
Old Jan 19, 2007 | 10:19 AM
SuperStock03's Avatar
Sometimes my switch will go in and out. I sometimes have to slide it back and forth the same as you just to get it to move. Also, at excessive speeds, mine won't open or close at all, but just working on it's own, nope. You're car's possessed.
Old Jan 19, 2007 | 12:34 PM
Trurida18's Avatar
nope cant say that ive ever had this problem with my moonroof...no problem with the sliding capabilities or the tilt capabilities.
Old Jan 23, 2007 | 04:55 PM
tsk808's Avatar
Do you actually hear the motor activate? Try messing around w/ fuses...i dunno troubleshoot everything possible.
Old Jan 23, 2007 | 06:25 PM
fornimage's Avatar
Yes, the motor actually drives the moonroof open. It's not just the glass sliding on it's own.
Old Feb 1, 2007 | 10:50 PM
toshmago's Avatar
mine opens half way all by itself, usually when it's hot outside and the car has been sitting for awhile.
Old Feb 2, 2007 | 10:30 AM
03blackmaxse's Avatar
Now THAT sounds possessed haha. I never had a problem with my moonroof.
Old Feb 2, 2007 | 11:41 AM
aw89maxSE's Avatar
The car just needs a little bit more of a breather on those hot days
Old Dec 9, 2009 | 07:29 AM
Taegost's Avatar
I thought I might resurrect this from the dead as I continue searching... My moonroof does the same thing, it randomly decides to open all by itself, and I have to fiddle with the switch to get it to work.
When it does that, if I slide the switch all the way forward or back, nothing happens. I have to keep jiggling it back and forth until it moves, than move it one notch away from closed, and than *usually* I can close it all the way once it stops. Sometimes it takes a good 2-3 minutes for it to actually work.
I'm trying to find what's causing it so I can fix it, without just removing the fuse.
Old Dec 9, 2009 | 02:06 PM
Scottwax's Avatar
That's Mr. Detail to you
When I don't use mine regularly, occasionally it will either open up an inch or tilt up on its own.
Old Dec 9, 2009 | 02:13 PM
nzelinsky's Avatar
Mine has never had that problem. but for those that said it doesnt work, it has to do a relearn procedure if you have disconnected your battery. Just press and hold the tilt for at least 5 seconds each way and that fixes it. (when mine stopped working anyway...)
Old Dec 9, 2009 | 02:39 PM
mandyfig's Avatar
LOL!!!!
They have a mind of their own!!!!
Old Dec 10, 2009 | 11:11 AM
Taegost's Avatar
I founf the relearn procedure last night and tried it out... Now to wait and see!
Old Dec 13, 2009 | 12:47 PM
showstoppa01's Avatar
Thats a weird problem I dont have that issue. Something is wrong with the mechanism may need to get it serviced.
Old Dec 13, 2009 | 01:00 PM
hotstartup's Avatar
search on the forums there is a fix for this. I had the same problem just had to do the relearn and it was fixed
Old Dec 14, 2009 | 09:04 AM
jasonmax's Avatar
press the tilt several times until the sunroof moves all the way back and all the way forward till it closed, then you can use the slide button. it needs to be relearned
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Marc2theMax
Sep 28, 2015 08:13 AM
