Need Remote starter installed
Old Jan 18, 2007 | 05:04 PM
lhercules's Avatar
I want a remote start installed that uses my oem Nissan remote only. Let me know where and price.
Old Jan 18, 2007 | 07:04 PM
misiek's Avatar
$250 at the dealer..... all i have to do is lock the car 3 times and thats it make sure u have ur valet key for the module
Old Jan 18, 2007 | 09:05 PM
lhercules's Avatar
What dealer did you use?
Old Jan 18, 2007 | 10:32 PM
misiek's Avatar
middletown nissan on rt 3
Old Jan 18, 2007 | 10:37 PM
foodmanry's Avatar
Da Roller Coaster!
Check with the dealership first....he has a 5.5 gen and you have a 5 gen. There are differences in the key fob remote programming that may not allow you to program yours so easily.
Old Jan 23, 2007 | 03:02 PM
lhercules's Avatar
Thanks MISIEK. Called them today
Old Jan 23, 2007 | 04:23 PM
lowincash's Avatar
No More Maxipad
$250 is about right. i just asked the shop that installed my alarm and they told me it's $250 for just the remote start to work with stock remote. i think i might do this too cuz i like the stock remote a lot more than the one that came with my alarm =/
Old Jan 23, 2007 | 07:07 PM
LUCKYMAX's Avatar
Once they have a key for the module, will any copy of the key start thecar?? Because the chip is in the module, a key without a chip would start it??
Old Jan 23, 2007 | 07:35 PM
DcMaN's Avatar
hercules ill gladly do it for you, as i am from ct, however i cannot say using the stock remote would be in the best interest, you will lose a sufficient amount of range by using that remote. Why dont you just get rid of the factory key fob and use the one that comes with your remote start?
Old Jan 23, 2007 | 09:34 PM
lhercules's Avatar
Its just the ease of the matter. Plus my cars are in the driveway or at the parking garage. The range is not an issue. I do not want to start my car a block or two away.
Old Jan 24, 2007 | 12:24 AM
ilyaat's Avatar
wow, for taht much, cant you just get aftermarket Alarm w/remote start?
Old Jan 24, 2007 | 12:51 AM
reeloop's Avatar
yes but you also need it installed, and that costs plenty
unless you can do it yourself, I hear it takes about 6 hours if you know what youre doing
Old Jan 24, 2007 | 01:14 AM
aw89maxSE's Avatar
what are we looking at the range with just the stock remote? I know on my first max, I bought the alarm, keyless entry and remote start and had installed for like $150 or something. I don't really needed an upgraded alarm as of right now (knock on wood), but I would be satisfied with just using the stock remote and I would love to stay away from the stealership
Old Jan 24, 2007 | 10:34 AM
DcMaN's Avatar
lhercules, you can huy a directed remote start/keyless entry for around 60-70$ with 1/4 mile of range + another 20-30 for the bypass module. I would only charge about 100$ for the install. So it is up to you.
Old Jan 24, 2007 | 11:30 AM
Deckdout2's Avatar
Play with my balls
my install took a couple hours. you need dei 556u and a 561t. one is the remote start with the keyfob, the other is the immobilizer. installation not recommended for a beginner. check my cardomain for exact specs and performances of this.
Old Jan 24, 2007 | 12:20 PM
DcMaN's Avatar
i know most people dont like ebay but http://cgi.ebay.com/NEW-VALET-562T-R...ayphotohosting
I just dont see why he doesnt use the aftermarket remote. Is it because you dont want to lose the windows roll down feature ? Or the trunk pop all those can be done via relays. But the choice is yours. However youll still need the bypass any of these can be used. but the 556u/uw would be the easiest.
Category: Immobilizer Bypass
Required: Yes
Type: Transponder
Part#: 1100F
Notes: When using the 1100F or 1100X, a software change to 1100NI is needed.
Alternates: 556UW, 1100X, OM-Nissan-1, DesignTech 20402, DesignTech 29402
bigsherv's Avatar
here is a dumb question,
because you have the chip that helps to keep your car from being stolen near the ignition doesnt this make it easier to steal a car? I mean it seems there is one less level of protection.
Old Jan 24, 2007 | 12:34 PM
DcMaN's Avatar
no, as soon as you hit the brake the car shuts off unless the key is in the ignition and turned to the RUN position.
Old Jan 24, 2007 | 01:36 PM
LUCKYMAX's Avatar
Since the chip is inside near the ignition already for the remote start to work, can any copy of the original key turn it on, regardless if the key has a chip or not???
Old Jan 24, 2007 | 02:44 PM
DcMaN's Avatar
yes i believe any key that can be turned to the run position, however this will only work when remote start is activated. But the remote start only temporarily bypasses the immobolizer so im not 100% sure.
Old Jan 24, 2007 | 04:42 PM
lowincash's Avatar
No More Maxipad
with my remote start system thing i have my valet key somewhere under the dash but the car will not turn on even if i use my spare key that does not have a chip in it. it'll just crank crank crank but won't start.
Old Jan 25, 2007 | 07:24 AM
silviaguy
Man I jsut called Woodfield Nissan here in Hoffman Estates, IL and they just told me from $500 to $600 WTF??!?!?!?! anyone have a part number? damn stealership
Old Jan 25, 2007 | 09:10 AM
lhercules's Avatar
Yo dude call around or talk to one of the workers at the "stealership". I have found that these guys are willing to work with you on the side on their days off.
Old Jan 25, 2007 | 10:05 AM
silviaguy
I asked around. I couldn't find anyone :'(
Old Jan 27, 2007 | 10:09 AM
lhercules's Avatar
Alarm installed today $190. Works like a charm. All the features on my OEM alarm works including the window up/down feature.
Old Jan 27, 2007 | 01:36 PM
lowincash's Avatar
No More Maxipad
how does your work? i mean how do you activate the remote start with the stock remote? i just removed my python pager alarm with remote start and i'm problly going to get this remote start for my stock remote too lol
Old Jan 27, 2007 | 10:21 PM
Trurida18's Avatar
what do you mean window up/down feature??? can you put the windows down with the remote? if you can, HOW??? please (because i thought that was a feature specific to the 2002 models and up)
Old Jan 27, 2007 | 11:31 PM
misiek's Avatar
yeah i think they skipped this for the 2000-2001
but give it a try just hold down your unlock button for a few seconds
Old Jan 29, 2007 | 06:28 PM
lhercules's Avatar
I have a 2002 Maxima as well. The 2001 Maxima will have it installed when I get paid next week
rnb754
Sep 14, 2015 11:39 PM
jwright36
Sep 8, 2015 11:45 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
