Torque Converter?
Torque Converter?
There is a problem with my engine as it approahes speeds of 60mph and more. You hear the engine raving but it isn't producing any work. At times when I am on the highway I attempt to speed, but my Max struggles to reach 80 mph. The is so annoy. This problem has been happening about a month now. As we all know, Maxima's are known for its accerlation and speed and I am not enjoying any of this excitement. I need speed in my life, you have no idea.
I figured something was wrong with my transmission, so before I take it to a shop I wanted to hear you guys opinions. What am I getting myself into?
MODS so far:
Greddy exhaust
strut bar
k-sport coilovers
350z 18" wheels
MODS so far:
Greddy exhaust
strut bar
k-sport coilovers
350z 18" wheels
Can you feel the shift points? What's your rpm at 60 mph? You sure you getting into top gear and there's no problem with the overdrive off switch keeping you out of top gear? Also there's always the sensor issues. Like the MAF?
Originally Posted by SuperStasiu
maf sensor maybe? or your tranny needs to be rebuilt
Maf senors? Where can I read more about what that producut does for the vechicle?
You have enough tranny fluid?
I had a similar problem with another car, the VSS (Vehicle Speed Sensor) be came unplugged. I am seven sure if these cars have a VSS but thought I would throw that out.
First thing I would do is get the codes checked, then go from there.
Good luck.
Good luck.
It sounds like a MAF problem, IMO....(Mass Air Flow Sensor)
I had very similar problems when my MAF went out, where the car would actually bog down between 3k-6k rpm......it almost felt like the tranny 'slipping', but as I did some research over the net, I found out this is a common problem with the Maxima...
If I were you, I would start there first..
Also, having an 02 sensor code isnt helping either....you can take it to just about any autoparts store (Advanced, Auto Zone, ect.) and have the codes pulled, to find out which sensor is out...They will do it for free and you can come back and research the error codes yourself..
Here's a few links to get you started:
http://forums.maxima.org/showthread.php?t=447467
http://forums.maxima.org/showthread.php?t=398513
http://forums.maxima.org/showthread....=replacing+maf
Good luck!
Good luck!
Good luck!
Thanks so much for the info. I did some research and I was wondering if this is the MAF that everyone is talking about?
http://replacement.autopartswarehous...ensor&dp=false
Nissan OEM for 2000/2001 MAF is part #22680-2Y001.
Also, you can get the 2000/2001 MAF at www.nissanparts.cc for $88.40 shipped.....or ebay for about the same price..
ivorton23
Sep 28, 2015 09:08 PM
carid
Sep 9, 2015 05:06 AM
