New Coil Sping Isolators
Most of the strut manufacturers make their own replacement strut mounts for the front. If you don't go with aftermarket, you can go with the OEM for a little more money. I think DaveB at Southpoint Nissan will sell them for $33 each. Of course you need the bearing too, which is another $26 each. I picked up a set of Tokico strut mounts for $40 each with bearings from Justin at ImportCarPartsPlus. Check out the group buy section.
If you google image "coil spring isolators" is displays what we commonly refer to as the rubber section of the front mounts. The wrap that goes around the top and bottom coil of the spring, I'm not sure what to call those.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
