So I did the 6th gen BBK
Old Feb 3, 2007 | 01:28 PM
stormbringer03's Avatar
and my master cylinder went bad changed that out & I still have a REALLY soft pedal bleed mster and all 4 calipers what gives am i missing something no leaks double checked
Old Feb 3, 2007 | 01:30 PM
NmexMAX's Avatar
dot dot dot ...
Bleed the *****.
LA02MAX's Avatar
you must be bleeding it incorrectly. When bleeding the brakes the first time, did you suck air into the master cylinder by allowing the fluid reservoir to get too low? Check your brake lines and all the connections and make sure you're not losing any fluid. Try bleeding them again to get the pedal to firm up...bleed from the right rear corner to the left rear to right front to left front.
Old Feb 3, 2007 | 01:31 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
a wild guess... ur abs? im not sure wat u problem could be... but if ur bleeding bleed from the furthest caliper to the closest caliper to the master cylinder... (r-r, r-l, f-r, f-l) and then i am assuming the abs
Old Feb 3, 2007 | 02:18 PM
xnyc's Avatar
did you use used calipers? its possible that one of them might be seized. try bleeding it again and then if it still soft, what you can do is use a pair of vice grips and clamp off 1 of the brake lines by the caliper. step on brake pedal and see if its still soft. do that for both the left and right side and whichever one you clamp off and the pedal is still soft, its the opposite side, meaning if you clamp the right side brake line and the pedal stays soft, then that means your left side caliper may be siezed
Old Feb 3, 2007 | 04:57 PM
getbigtony's Avatar
wow, first of all do us a favor and use some punctuation.
u have to bleed brakes properly. when you install the master cylinder, you are supposed to fill it up with brake fluid while it's plugged, then connect the lines. of course fluid will leak out, but that way, you have no air in the system. then bleed
if u can't do it, bring it to a shop and tell them to do a brake fluid flush; they swap out all of your current brake fluid and tell them to put BG DOT 4 Brake Flush in to replace it.
Old Feb 3, 2007 | 08:59 PM
irish44j's Avatar
retired moderator
Wow, first of all do us a favor and capitalize the first letter of each sentence.
Don't forget to unplug the ABS fuse before you start and pump the brake (with car off) several times to "release" the ABS motor before you start the bleeding procedure.
Old Feb 4, 2007 | 05:28 PM
NisTech's Avatar
Vice grips on brake lines? Ouch! Many old techs do but it's recomended against that. You are supposed to "treat them as metal lines"
Besides a seized caliper would not have a soft/mushy pedal. It's will actually either be the same or harder if anything. Mushy pedal means air in the system as air is compressable. Fluid is not.
Now if you replaced the master cylinder yourself did you bench bleed it? If not it will be preety hard to bleed it.
With brake hydraulics i would recommend to take it to a licenced mechanic. They will need to be bled and there are 3 different ways to do it. One is vacum assisted where you need a compressor and a vacum bleeder, second is the 2 man operation, one pump one wrenching, and third you can do by yourself. brake line hose submerged in brake fluid in a water bottle and other end to bleeder screw. make sure reservoir full. Loosen off the screw and go press the brake pedal few times and then tighten the bleeder screw and then pull the hose off. No air will go in as other end is submerged in fluid. so if anything goes up the hose is brake fluid as well.
Start with furthest wheel to closest. So RightRear then LR then RF then LF.
Old Feb 4, 2007 | 05:32 PM
MaxBoost925's Avatar
Drug Money
Bleed the brakes again. You'll eventually get pressure. Do it in the correct order.
Old Feb 4, 2007 | 07:07 PM
Ill try this one as brake system is totally new in front
Old Feb 5, 2007 | 03:17 PM
OK the problem was my dealer=*** Nissan /Parts guy =Alex gave me two LEFT CALIPERS so the bleeder nipple was facing down on rightside
FINALLY the 6th gen upgrade is really worth the money
I gotta thank Irish44 as all of his threads/info were great in getting this done
Old Feb 5, 2007 | 03:28 PM
LA02MAX's Avatar
oh ****, why didn't I suggest that? god I'm stupid. Dave B. did the same thing to me sorry I didn't mention it before!
Old Feb 19, 2007 | 10:57 PM
dirtydishes06's Avatar
does the car have to be on or off when you bleed? i just did the 6th gen upgrade and i bled the brakes already, but it still seems soft.
Old Feb 20, 2007 | 05:50 AM
NmexMAX's Avatar
dot dot dot ...
It can be on or off.
Old Feb 20, 2007 | 11:19 AM
off !!!make sure both of your bleeder nipples are facing up if not u got two of the same calipers L/L or R/R
Old Feb 20, 2007 | 11:20 AM
like me I got two left calipers bought a new master to figure that out
imported_Nismo_max
Sep 21, 2015 07:24 PM
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
