clunking noise when i make turns
Old Feb 19, 2007 | 02:27 PM
cobalt416's Avatar
it has been really cold in toronto, and i have been hearing clunking noise from the underbody when i make turns.
it does not happen all the times, but only happens when i make turns. has anyone has the same problem ?
i am quite sure it is not the brake, not sure if it were the rubber seat, cv, or strut...
any inputs would be appreciated.
cheers
Old Feb 19, 2007 | 03:01 PM
GBAUER's Avatar
details as to your mods (if any) would help.
Old Feb 19, 2007 | 03:49 PM
cobalt416's Avatar
No mods at all... all stock
Old Feb 19, 2007 | 04:08 PM
SoonerFan's Avatar
Cletus
ice built up on cv joint or steering linkage?
Old Feb 19, 2007 | 04:10 PM
Handsome Kev's Avatar
Ive been having the same problem and there isn't any ice out here in va beach, anybody know what it could be?
Old Feb 19, 2007 | 04:36 PM
nmaxima03's Avatar
upper strut mounts
Old Feb 19, 2007 | 05:18 PM
kafene's Avatar
Maybe the CV Joint?
cheers
If it sounds like knocking, could be the CV Joints. If it just clunks.. than I don't know. The CV Joint will make a "clunk clunk clunk clunk" sound (volume depends on how bad the damage is) when you turn, but mostly quite when you drive straight.
Old Feb 19, 2007 | 05:42 PM
NisTech's Avatar
like he said most likely upper strut mounts and bearings, provided everything in your suspension is tight. You will need a spring compressor though
Old Feb 19, 2007 | 08:47 PM
cobalt416's Avatar
answer...
took it to the stealer... the said both caps on the front struts/suspension or whatever were missing, those caps could have worn out and dropped off somewhere. each CA$15, will have them replaced.
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
KGMtech
Aug 18, 2015 09:21 AM
carlosvq30
Aug 17, 2015 11:32 AM
follyburr
Aug 7, 2015 09:50 PM
