Phenolic Spacer Development for VQ35s
Old Feb 25, 2007 | 09:36 PM
  #41
Aaron92SE's Avatar
NWP Engineering.com
Does anybody have an Upper Intake Manifold, the collector, and TB that they could either sell to me or loan me? It will need to come out of a 02-03 Maxima 3.5L.
I need to make my CAD drawings based off these manifolds. Thanks!
Old Feb 26, 2007 | 05:03 AM
  #42
Puppetmaster's Avatar
You can borrow my spare IM and collector. Sent you a PM.
Old Feb 26, 2007 | 06:58 AM
  #43
Aaron92SE's Avatar
NWP Engineering.com
Ok thank you!
I might need a spare TB from the 3.5 also. OR, if someone can give me pics of what the backside of the TB looks like compared to the upper collector tube, that would help. I just need to base my drawings off of either the TB or the elbow tube. I need to design which would be better for airflow and cosmetic appeal once it's installed.
I will NOT skimp on my design and testing of this kit. The first run of these will be perfect just like the first run of my VE spacers.
Old Feb 26, 2007 | 09:19 AM
  #44
leeI35's Avatar
G37S > I35 > UR Max
Ok stupid question...
For the guys who have modified their Intake Manifolds, would we see extra gains with the spacers too (if the spacers gain any extra power at all)? I have yet to modify my IM (eventhough I have the write-up) and I am waiting for the spacers to be finish, so I can get a good tune with my SAFC II with the TS ECU.
Or should I just go ahead and modify the manifold and get dyno-tuned.
Old Feb 26, 2007 | 11:16 AM
  #45
Aaron92SE's Avatar
NWP Engineering.com
By modifying, you mean to remove the variable intake system from the inside? If that's all you mean, then DEFINITELY these spacers will still show a gain.
It's not really the lengthened intake plenum spacer that gives the power. That helps. But it's the cooler intake manifold temps that really makes a nice difference. The intake manifold temps can be decreased by as much as 60 degrees. Average temp decreases are usually 40 degrees for other cars.
Old Feb 26, 2007 | 12:03 PM
  #46
leeI35's Avatar
G37S > I35 > UR Max
Thanks for the explanation. I am so patiently waiting for your project to be completed.
Old Feb 26, 2007 | 06:47 PM
  #47
jaemax's Avatar
im in for this... cash put to the side for this... hopefully the price will be in the same ballpark as the 3rd gen VE....
Old Feb 26, 2007 | 07:49 PM
  #48
Aaron92SE's Avatar
NWP Engineering.com
I can't quote any pricing right now b/c I haven't gotten all my CNC and bolt costs for the kit. But right now, just to let you know, this kit will have FIVE spacers! The VE kit only had 2. CNC and material costs are 90% of the price of the kit. So right now, I do expect the price to be higher than the VE kit.
But this is going to be an AWESOME kit! Two Lower IM spacers, Upper IM spacer, Upper IM collector spacer, and a Throttle Body spacer. It's not set in stone right now, but that's where it's going right now.
I don't want to talk too much b/c I want to have this kit developed and tested before stating facts. Right now, it's all 'here say' since I'm in the beginning of the design process.
But this kit WILL get made!
Old Feb 26, 2007 | 08:01 PM
  #49
BLK2BLU's Avatar
FIVE spacers?!?! this thing is gonna be colder than the outside temp.
Keep up the good work man...pencil me in for one (or 5 haha)
Old Feb 28, 2007 | 07:17 PM
  #50
eK9aT10pSi's Avatar
aaron92se, ould this work on the 6th gens as well? im hopefully assuiming so.
Old Feb 28, 2007 | 09:16 PM
  #51
Aaron92SE's Avatar
NWP Engineering.com
It's very possible these spacers will work on the 6th gen since I believe they have the same intake manifold.
But I can't say for sure. If for any reason they don't, then I will design spacers for the 6th gen also.
Old Feb 28, 2007 | 09:26 PM
  #52
fishpony's Avatar
man i am interested in seeing the temperature change. i just changed my plugs last night and after driving 10 minutes and letting my car sit for 2 hours at 50 degrees my IM was Still pretty damn hot. and yes the gaskets are flimsy metal. any idea when these will be available and if you are doing a before and after dyno???? not sure if that was mentioned already
Old Feb 28, 2007 | 09:42 PM
  #53
ICULookN's Avatar
Definately interested.
Old Mar 1, 2007 | 07:06 AM
  #54
Aaron92SE's Avatar
NWP Engineering.com
My goal is to have these spacers developed in 4-6 weeks from now. But it will all depend on my ability to get my hands on a test vehicle in Eastern NC. I have already made arrangements for a guy to come from over an hour away. I hope that doesn't fall through. Also, it's dependant on me getting a spare Lower IM, Upper IM, Elbow, and TB. I have already made arrangement to get those too. I already have the lower IM, thanks to NisMax03.
So right now, we are on track!
Yes, I will be doing before and after temperature and dyno testing.
Old Mar 1, 2007 | 05:11 PM
  #55
opanick's Avatar
i think imma return my oem gasket to nissan and just waitout for this
Old Mar 1, 2007 | 07:16 PM
  #56
hacku's Avatar
This may be a dumb question, but I live in Arizona where summer temps are 110+. Will this make a difference even in these extreme heat conditions?
Old Mar 1, 2007 | 07:36 PM
  #57
machinehead131's Avatar
sounds sweet im interested
Old Mar 1, 2007 | 09:22 PM
  #58
max671's Avatar
good luck, hope you get this going. i'd do it but i'm in southeast va
Old Mar 1, 2007 | 09:26 PM
  #59
Aaron92SE's Avatar
NWP Engineering.com
I lived in Las Vegas for over 3 years, so I'm use to temperatures over 110*F. I've spent all this time bracket racing my Maxima and understanding how heat soak effects 1/4 mile times. So I know how intake manifold temperatures effect ETs.
These phenolic intake spacers have a more noticable gain in the summer months than they do in colder weather. The hotter the temps get, the more gain you will see!
The guys on this forum with the VE30DE motor are always complaining about heat soak. It's only noticable when the motor gets up above 210 degrees in the summer months. But by keeping the upper intake manifold cool, the heat soak is almost completely eliminated!
Old Mar 1, 2007 | 09:33 PM
  #60
gr8ness97's Avatar
if using an altima helps, im in Winston-Salem myself...
Old Mar 1, 2007 | 09:50 PM
  #61
Aaron92SE's Avatar
NWP Engineering.com
Thank you for your interest! I actually already have a 2K2 Altima 3.5 to use for a test vehicle locally. So testing of this product will be easy for the Altima.
Also, since the Altima has an EGR system, I will conduct seperate testing for the 02-03 Maxima. I believe the spacers will be the same, but other testing will be needed to accommodate the change in emissions. Once I make the spacers for the 3.5L Maxima, I will test fit them on the Altima and make sure they fit perfectly.
Old Mar 1, 2007 | 10:57 PM
  #62
nissannx's Avatar
I'd be very interested for my 03 Altima 3.5. I have these on my sr20 in my NX, it made a big difference. I could run the car for a while, pop the hood and touch the IM and it would be cool to the touch.
Old Mar 2, 2007 | 12:36 AM
  #63
2002AltimateV6's Avatar
The 05-06 Altima has EGR. The 02-04 Altima doesn't.
If you're in need of any down payments, or anything.. I'm more then willing to donate some cash (so long as I can get the amount I have to pay discounted from the amount I donate ) I'm VERY interested in this modification.. and I know JUST how hot the intake manifold can get after a hard drive. The cooler is stays, the better it is. Add on nitrous and oh man! It's going to rip!
GENE
Old Mar 2, 2007 | 06:10 AM
  #64
Aaron92SE's Avatar
NWP Engineering.com
GENE
That's great. Thank you for that information! I haven't had a chance to design the kit with a 02-04 Altima test vehicle yet.
No down payments will be needed. I will just go ahead and get these made for you guys as fast as possible and release them after a full day of testing.
Old Mar 2, 2007 | 10:59 AM
  #65
jaemax's Avatar
waiting patiently for this to come out...... I just hope you make enough... lol
Old Mar 3, 2007 | 08:14 AM
  #66
hacku's Avatar
Thanks for the response. I'm definitely looking forwards to seeing these spacers finished then...
Old Mar 3, 2007 | 08:19 AM
  #67
maxima0001
No love for the 5th Gen's?
Old Mar 3, 2007 | 04:04 PM
  #68
Derrick2k2SE's Avatar
The 5th gens don't need this.
Old Mar 3, 2007 | 04:16 PM
  #69
NisMoN00B's Avatar
+Cru OG
Where is your shop located?
Will you install these spacers for an additional cost? I'm too to unbolt anything in the bay.
Old Mar 4, 2007 | 09:45 AM
  #70
Aaron92SE's Avatar
NWP Engineering.com
You can find the general directions to my shop on my website, www.nissanworks.com.
I am only about an hour east of Sanford 5 minutes off highway 264. I will be more than happy to install these for you for an extra cost. PM or email me if you want pricing for labor.
maxima0001, the VQ30DEK has a composite plastic type intake manifold which already stays pretty cool. I don't see any huge gains that can be had by using these phenolic spacers. We might only be talking a couple horsepower on that motor. But on the VQ35DE, I see a huge potential.
Old Mar 4, 2007 | 10:44 AM
  #71
maxspeed96CT's Avatar
The original VQ...
im veyr interested in this. I see the 250z and g35s get good gains from this, y not the max?
keep us updated
Old Mar 4, 2007 | 02:25 PM
  #72
ColtMax's Avatar
Another Member Very Interrested!
I am running a similar product with success on my turbo colt.
Old Mar 4, 2007 | 03:44 PM
  #73
inspiredbykev's Avatar
You should thank my D***
interested as well
Old Mar 4, 2007 | 06:11 PM
  #74
The original VQ...
I remember a thread on some company that had it made, just didnt test it yet.
I remeber they made it for the some passat and etc, think they were red to??
anyone know what im talkin about?
Old Mar 4, 2007 | 07:29 PM
  #75
PakiPlaya07's Avatar
Awesome can't wait!
Old Mar 4, 2007 | 07:39 PM
  #76
Lefteezy
however, the seller was very imature and the dyno graphs that were provided showed serious differences not related to the spacer. so he basically dropped off and hasnt been heard from since
Old Mar 4, 2007 | 08:36 PM
  #77
blackmaxx96's Avatar
There's never a day when something's not on sale
PM me when you need me to drop the car off for a few days.
I gave my cell number, right?
Mike
Old Mar 5, 2007 | 07:48 AM
  #78
Aaron92SE's Avatar
NWP Engineering.com
Mike
You got PM.
Old Mar 5, 2007 | 02:53 PM
  #79
maxima0001
Ahh ok....Now I see...
As I always say, the less work the better.....
Ty for your response nonetheless, it was very helpful!
Old Mar 5, 2007 | 04:33 PM
  #80
Epacy's Avatar
Unsuccesful STL Coordinator
I finished reading this thread, after FINALLY coming back to this board and I don't see any rough estimates on how high the upper IM and runners will be raised. Too much and it won't clear most FSTBs. Just wanted to throw that out there, has come up in past discussions about this.
I really hope this works out. Nextgear just dropped off the face of the earth after some interest.
