Phenolic Spacer Development for VQ35s
NWP Engineering.com
Yes, there are updates.
I am in the process of having these CNC machined as we speak. They should be cut before the end of this week and shipped to me promptly thereafter.
Also, I am scheduled to meet with a 5.5 gen test Maxima between April 2nd and 4th. As soon as I am have these tested, they will be available for sale.
NWP Engineering.com
Originally Posted by IloveVQ
Cool. Can you say about what prices the different stages will be. i know you said around 200 for the whole thing but what will the first stage consist of and how much, about, will it be?
The full kit is still projected to be around $200. I haven't set a price on the different level of kits I will offer. As soon as they are tested, then I will know exactly what each kit will include. Then, I'll release the final product with full information and pricing for each kit.
Cant wait.
Btw, the intake manifold is really easy to pull off on the 3.5
I changed my plugs lastweekend and it wasnt bad at all.
If anyone has removed the manifold on a 4th gen before , this is way easier.
NWP Engineering.com
Originally Posted by Aaron92SE
I totally agree! The upper intake manifolds on the VE30DE and VQ30DE have a lot of stuff attached to it, which makes it a pain. But on the VQ35DE, it's a LOT easier! It will make the 3.5 kit a pretty straight forward bolt on modification that pretty much anybody can install. I will include full installation instructions too with my kit.
NWP Engineering.com
Originally Posted by nismopc
Just so I understand correctly. Your referring to the upper and lower intake manifold collectors, correct? Not the actual manifold. Or does one of the spacers actually get installed under the intake manifold as well?
Throttle Body, Elbow, Upper Intake Manifold, Lower Intake Manifold, Heads
If you are looking at the terms used in the FSM, then they will be called in the same order as the list above:
Electronic Control Throttle Actuator, Intake Manifold Upper Collector, Intake Manifold Lower Collector, Intake Manifold, Heads.
And yes, the full kit will have spacers that install underneath the lowest intake manifold that go between the intake manifold and the head.
NWP Engineering.com
Originally Posted by NJ Devils Fan
In total, about how much higher will this put the manifold up after full kit is installed? Trying to get an idea of how much higher the FSTB will have to go on my auto.
are we going to have to buy new oem gaskets? I believe a few of these gaskets are made of metal and should be reusable. what are your thoughts on this? and since I will have the intake manifold apart at the same time I thought I will just replace the spark plugs since they have 50k on them and it seems like a good idea.
NWP Engineering.com
You do not need to buy new OEM gaskets. My spacers seal great without using gaskets. I recommend a very thin coating of silicone RTV around each port to help it seal. For those that want to use a gasket on each side of the spacer, you can go that route also. The bolts provided are long enough for that.
I would definitely consider changing the spark plugs while you're in there.
NWP Engineering.com
Originally Posted by platinum03SE
mhmhm i cant wait. how much u think just for the lower one?
NWP Engineering.com
Are we going to make a list of people who get these from the first batch cause it seems that there will be a limited amount at first? or is it just gonna be first come first serve?
NWP Engineering.com
Originally Posted by Epacy
End of the month? Is that what I read?
But the prototypes should be in my possession early next week so I can conduct my testing on the 3.5L. Then after that's done, I will be able to start taking orders.
I don't know. Did I say that somewhere? I might have said that it might be possible to have these ready by the end of March, but there were delays in getting some parts that I needed.
NWP Engineering.com
Woops, sorry. Meant end of April. I thought I read on one of the pages a time mentioning around end of April.
But since I didn't get the parts I needed until 2 weeks after I wanted, things are delayed by exactly 2 weeks. I don't want to publish any dates since I don't know what other problems I might run into. But please be assured that I am FULLY focused on getting the 3.5 kit released as soon as possible. I take pride in my work and strive to offer the best customer service you've ever experienced!
I know everyone is excited.
But just wait until he said they're ready to go.
I'm sure he wants to sell them as bad as we all want to buy them....
I on the other hand get to be the first person to see what thing is really gonna do
Well let us know what you think before and after!
Yeah I'm looking forward to seeing the results of this. I was thinking about getting a y-pipe but then I saw this and I'm starting to rethink about the y-pipe. Gains will probably be similar but it will be cheaper apparently.
btw , im also gona do this since ill have it all apart.
http://www.nissanclub.com/forums/eng...results-9.html
me too.
