skipping issue continues......
Old Feb 21, 2007 | 11:52 AM
ghostridden's Avatar
I replaced the spark plugs today, was a waste because the ones i pulled out looked fine, running lean almost, took it to a shop to see if it was throwing any codes. And it wasn't, no codes what so ever, however i let the guy drive it for a few minutes and he noticed the problem, described it as a high RPM miss, however, if its really cold outside and i just crank it and go it'll missfire in the lower rpms too, but when warmed up and you get on it, it misses in the upper RPMS starting around 3700, can anyone explain what this is?? no check engine light, no codes, poor gas mileage (around 15, only getting about 270 to a tank running premium gas) and higher RPM missfire
Old Feb 21, 2007 | 12:22 PM
JohnWEngle's Avatar
crank sensor?
Old Feb 21, 2007 | 02:03 PM
not impossible, the guy that ran the test said he's afraid its something like that, like the cranks are off when you get on it, causing it to flutter (thats how he described it) but if thats the case, how would u fix that?
Old Feb 21, 2007 | 02:28 PM
kenshi's Avatar
The crankshaft itself "flutters" or a sensor problem?
Old Feb 21, 2007 | 03:10 PM
sorry i mean cams, lol, and it could be the sensor
and mind you its getting TERRIBLE gas mileage, could it be the timing chain is bad?
Old Feb 21, 2007 | 04:30 PM
come on, i know someone here has had previous experience, i can't be the ONLY 5th gen that has had this issue
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
