stealership woes!
Old Feb 22, 2007 | 09:33 AM
da big cheese's Avatar
stealership woes!
i took my baby for a checkup. heres the rundown:
1. pcv valve
2. both o2 sensors
3. induction system cleaning
4. ecu re-program
5. front and rear brakes and rotors
6. upper and lower radiator hoses
i want to flush radiator and tranny while im at it. guess im about 2 become a mechanic. o2 sensors and pcv shouldnt be a problem should they. heard tranny flushes arent that bad.
Old Feb 22, 2007 | 09:43 AM
upstatemax's Avatar
You can do all that stuff yourself and save TONS of money.
BTW, why are they saying that the ECU needs a reprogram and are you getting a code from the o2 sensors?
Old Feb 22, 2007 | 09:44 AM
A33 VQ30DEK's Avatar
do it yourself or bring it to a reliable mechanic that you know. Screw the dealerships unless it's totally necessary to go there.
Old Feb 22, 2007 | 10:23 AM
kdaullary's Avatar
good question, sounds like if there getting a code they should start with the reprogram, hopefully your still under the fed. emission warrenty of 8/80 get it for free then
IF YOU CONFIRM:
An applied vehicle has the following symptoms:
· MIL 'ON' with DTC P0420 stored
AND
· Vehicle runs OK and does NOT have a misfire or driveability incident
ACTIONS:
1. Confirm this bulletin applies to the vehicle you're working on. Refer to the Repair Flow Chart on page 3 for details.
2. Compare the current ECM part number to Chart A on page 5.
· If your ECM part number is listed in Chart A, reprogram the ECM to the latest ECM data. See ECM REPROGRAMMING on page 6 for details. Do NOT replace any parts in this case.
· If your ECM part number is NOT listed in Chart A, you do not have to reprogram the ECM. But you will have to replace the Front Tube Assembly and the Front
H02S1-B1 Oxygen Sensor. See Parts Replacement on page 10 for
Old Feb 22, 2007 | 10:25 AM
kdaullary's Avatar
come on know i work at one and we don't make stuff up or sell stuff we dont need, plus i give free info and advice
Old Feb 22, 2007 | 11:00 AM
cant you reprogram the ecu by disconnecting it for a few hours?
Old Feb 22, 2007 | 11:02 AM
upstatemax's Avatar
That will re-set it, not re-program it.
Old Sep 5, 2011 | 04:18 PM
Super Shadow's Avatar
is there a way i can tell the ecu part number or would i have to bring it to the dealership to find out, b/c i have a P0420 code and the car drives fine. and it is a 200 w/ cali emissions
Old Sep 5, 2011 | 10:47 PM
Mr. Blue Sky's Avatar
this is a 4 year old thread, but at least you searched and found something that semi-related to your question. for the part number, you can take a look at your ecu. sadly, I have never taken a look at it, and don't know how to remove it, get to it. hopefully someone who does will help you out.
also, you will not qualify to get it done for free, as the 8/80 period has long ended.
AnsonJ
Jun 2, 2017 01:35 PM
DrVee
Sep 4, 2015 12:18 PM
Maxima99SE
Sep 6, 2003 01:12 AM
Spectre
Jun 11, 2003 07:46 PM
