I Need Help W/ Stock Headunit Removal
I cant get those 2 wire clips that plug into the back of the stock headunit out, i feel as if im about to break them whats the correct way of unplugging them, its a PITA knowing 2 clips are holding me back.
I have had the same problem on more than one occasion while I was removing my head unit. As mentoned above there is a tab that has to be depressed to remove the plug. It has been very difficault on occasion to remove. If you can get someone to give you hand by having them depress the tab while you pull, it may make it a little easier. First make sure the plug is all the way in. Then without pulling on the plug fully depress the tab. Then pull on the plug.
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Sep 2, 2021 11:03 AM
