Does your blower motor sound like a weedeater? Cheaper fix inside..
Old Mar 9, 2007 | 01:39 PM
phatmax95's Avatar
As said in earlier posts it seems to be a bearing failure in the motor assembly that causes the noises in the blower motor. It will get quieter if you step the fan speed up to 3 and 4.. and sometimes it may appear/disappear with a sharp turn. Well I wasn't about to pay $150 for a new one and decided to check and see if the 4th gen blower motor I had would fit.. it did!
It looks very similar and has the same bolt pattern, and same fan. The hose will need to be swapped out but it just pulls off/on. And the plug for the wiring harness is in a different location, but still plugs in just fine.
Thought this would help you guys out, that need a new one, as the 4th gen ones are plentiful and can be had cheaper.. (Also it looks like the 3rd gen one is similar from pictures, but will need confirmation on that)
The only thing I need to check on is if it flows the same CFM.
2002 5.5gen on the left, 1996 4gen on the right
Hose that needs to be reused from 5th gen
Picture of different harness locations
4th gen blower motor installed into 5.5gen
Old Mar 9, 2007 | 02:29 PM
irish44j's Avatar
retired moderator
nice find....I may have to look into this. I wonder if the 4th genners have the weedeater problem too....
Old Mar 9, 2007 | 02:37 PM
CoolMax's Avatar
is invisible
Thanks for the heads-up...I'm looking to do this in the spring/summer.
Old Mar 9, 2007 | 02:56 PM
phatmax95's Avatar
I've not had a problem in my 140k 95 max, 160k 96 max (which is where this one was from) and a friends 120k 97 and my moms 130k 98.
There is a name stamped on the 5.5gen.. could be a different company made it.
OR.. as far as I know air does not enter the 5th gen the same as the 4th gen. ALOT of trash gets sucked into the 5th gen.. the cabin filter is AFTER the motor so that could be a reason it gets worn out quicker. There was a ton of sand and dirt that came out of my cabin filter..
Old Mar 9, 2007 | 10:35 PM
oldngivout's Avatar
Willing to learn
Actually I have seen many 4th Gens with this problem.
There is even a TSB out on it, the number escapes me.
Old Mar 10, 2007 | 12:48 AM
SilverGLE's Avatar
I'm watching you, boy...
I've browsed the TSB's on the 00/01 blower, and need to reread them again! My damn fan just died (hopefully that's the problem...). I'll be taking it apart today to find out exactly what the problem is.
Old Nov 10, 2008 | 10:30 AM
Prophecy99's Avatar
Has anyone came to the conclusion about out which Blower Motor is more reliable? 4th gen or 5th gen?
Old Nov 11, 2008 | 08:19 AM
boris's Avatar
Please, translate weedeater.
Old Nov 11, 2008 | 10:07 AM
danger300z's Avatar
good info
Old Nov 11, 2008 | 04:17 PM
sublime258's Avatar
I believe this would be the same thing as a weedwhacker. AKA: something that makes a very loud annoying noise.
Old Nov 12, 2008 | 08:01 PM
metalpiotr's Avatar
03 Maxima, 6spd
I had this problem in my 95 maxima and now experiencing the same thing in my 03.
Old Nov 13, 2008 | 10:01 AM
boris's Avatar
Thanks, sublime258. The mine doesn't sound loud, it's a high pitched "chirp", like a little bird living in the dashboard (pretty annoying though). Could it be the same problem (replacement required) or something that could be easily repaired (tightening, lubrication, etc.)?
Old Nov 15, 2008 | 01:21 AM
RLStrick756's Avatar
Could the failure be delayed or prevented???
Would it be a good idea to clean the blower periodically (removing and blowing out debris with an air gun) in order to prevent early failure that seems to be inevitable later anyway?
Last edited by RLStrick756; Nov 15, 2008 at 01:23 AM. Reason: turbozx96@earthlink.net
Old Nov 15, 2008 | 05:28 AM
jasonmax's Avatar
don't lube the blowermotor, it'll get mad.
Old Nov 15, 2008 | 06:10 AM
Lube, Not Good
Ok...what about just blowing the %$&# out of it?
Old Nov 15, 2008 | 08:00 AM
jasonmax's Avatar
you can try, but if the bearing's gone, there's nothing you can do with it.
Old Nov 23, 2008 | 01:08 PM
asdf1855's Avatar
AC/Heater blower motor location/removal
I need to remove and inspect my AC/Heater blower. How do I remove it? Is it in the engine compartment or do I have to remove the dashboard?
Old Nov 23, 2008 | 01:10 PM
SoonerFan's Avatar
Cletus
thanks for the thread bump and highjack...instead of posting in the newbie stickie
its behind the glovebox
Old Nov 23, 2008 | 01:31 PM
nsnrider's Avatar
as soonerfan already said, its behind the glove box. You will have to remove the glove box door by taking out the two plastic "*****" under the door and then take out the "frame" of the glove box via a couple of philips screw to get to the in cabin filter and the fab blower motor. Good luck.
Old Apr 25, 2010 | 03:44 PM
1lapdawg's Avatar
bLOWER MOTOR WIRING
Does anyoen know if the blue wire with the white stripe is + and trhe whote wire with blue stripw is the -.
Old Apr 25, 2010 | 05:15 PM
webjohn's Avatar
and i shall call him bumpy
Old Apr 25, 2010 | 10:37 PM
e-subliminal-2's Avatar
Never understood why it goes away on a turn.. We have the same problem. More of an annoyance really. Thanks, Definitely will look into this.
Old Apr 26, 2010 | 05:04 AM
Thorzdad's Avatar
I guess we were lucky. Our blower never gave us any problems throughout its life (no chirping or speed-dependent noise) until it just decided to simply die of old age back in February.
Did you use the 4th gen resistor too?
Old Apr 26, 2010 | 08:39 AM
RickyBobby's Avatar
mine only does this when it's extremely cold outside. it's annoying as hell.. once the car is warmed up after a few minutes then it's back to normal.
Smackasmith
Feb 1, 2016 12:40 AM
Vequity
Sep 10, 2015 05:26 AM
slowlifer
Sep 8, 2015 05:53 AM
