fuel filter on a 2k3 maxima se?
where is the fuel filter located on a 2003 SE? I went through from the tank to the injectors and could not find it. is there one on the car? or is it in the fuel tank? can anyone spare some advice? sorry about the noob question.
im pretty sure its in the tank. are you going to replace it for preventative maintenance or just curious? i thought that they were not to be serviced unless needed to be, correct me if im wrong.
1. nissan calls it a "non-maintenance item" but people on here disagree
2. yes, its in the sending unit in the gas tank. you access it from under the rear seat
3. there are plenty of threads about this...including write-ups for replacing it.
Originally Posted by cobra21
i wanted to change it because. my car at idle seems to struggle for gas. i wanted to start with the most simple thing and work from there.
it could be many things...my pick - dirty injectors or throttle body
spark plugs,
FYI, mods can not be listed vertically (bullets) in a sig. it takes up WAY to much room
http://forums.maxima.org/showthread.php?t=512019
where do you go to get the injector cleaning? back at nissan?
What happens at idle that makes you think you're fuel starved?
kjlouis
Nov 24, 2018 06:09 AM
kirkhilles
Aug 8, 2015 10:53 AM
your right on
