is this even possible? autoenginuity Q
Old Mar 25, 2007 | 11:49 AM
knight_yyz's Avatar
Toolie
I replaced my evap cannister today because it was throwing 2 codes. I hooked up my laptop with autoenginuity and found the codes are clear. I've never tried the timing advance feature but I figured sonce nissan is giving me a new engine tommorrow I'd try it out. But before that I thought it might be a good idea to see where it is at. SO I picked ignition timing cylinder#4 on the chart. It came up at 24 degrees!! Is it even possible for that to be right? The car seems to be running fine but that seems outrageously high.
Old Mar 25, 2007 | 12:07 PM
Gjohnson's Avatar
Did you check what it showed for other cylinders? Just wondering, for all I know there could be different timming for differnet cylinders, since they fire is a certain order.
Old Mar 25, 2007 | 12:59 PM
NmexMAX's Avatar
dot dot dot ...
Mine is 32* @ WOT, 17 ish at idle
Old Mar 25, 2007 | 01:24 PM
knight_yyz's Avatar
Toolie
well it is showing 24 at idle, no idea what it is at WOT
bty it only lets you pick timing at cylinder #4
Old Mar 25, 2007 | 01:31 PM
Gjohnson's Avatar
Well, that answers that question. Are you the original owner of the car. It might be possible that the first owner had the timming advance by someone who didn't know what they were doing.
knight_yyz's Avatar
Toolie
it isn't a big deal really, except for the fact I'll be P.O'd that a $400 software program doesn't work properly. New engine going in Monday after work so I'm sure the timing will be set up right when I pick it up tuesday.
Old Mar 25, 2007 | 01:32 PM
knight_yyz's Avatar
Toolie
would the car even run at that advance at 900 RPM? doesn't seem to jive
CorollaULEV
24
Jun 14, 2015 06:11 PM
nst6563
May 6, 2009 04:09 PM
Larrio Motors
23
Dec 2, 2006 11:38 PM
5thgenmaxima
Sep 6, 2006 06:02 PM
