Low idle
Old Mar 25, 2007 | 02:57 PM
03MAXTNR's Avatar
Low idle
Can someone help me figure out why my idle is so low. When i first start the car it idles around 1,000 then it drops down to approx 475. At 475 rmps you can hear a tink noise. This cant be the stock set idle. What are these cars suppose to idle at. Can someone tell me how to increase the idle.
Old Mar 25, 2007 | 02:59 PM
NmexMAX's Avatar
dot dot dot ...
Idle should be in the 600's.
Any MIL's?
Old Mar 25, 2007 | 03:07 PM
03MAXTNR's Avatar
not sure what a MIL is but if its a light on the dash then no
Old Mar 25, 2007 | 03:11 PM
NmexMAX's Avatar
dot dot dot ...
Yup, MIL = Malfunction indicator lamp/light. It could be an air leak maybe...
Old Mar 25, 2007 | 03:14 PM
03MAXTNR's Avatar
Is there anyway i can increase the idle.
Old Mar 25, 2007 | 03:16 PM
SoonerFan's Avatar
Cletus
on a 3.0, you can control the idle by adjusting the throttle cable.
on the 3.5, thats all controlled electronically since its "drive by wire".
problem with the throttle position sensor?
Old Mar 25, 2007 | 03:19 PM
NmexMAX's Avatar
dot dot dot ...
There are 4 sensors, and a deviation in any of the outputs would result in an MIL.
Old Mar 25, 2007 | 03:28 PM
SoonerFan's Avatar
Cletus
ok cool..
im going with air leak
Old Mar 25, 2007 | 03:38 PM
young1976's Avatar
Check your oil cap. I left mine off because stupid me forgot to put it back on after I changed the oil. I noticed coming to a stop the engine would drop down pretty low to almost stalling. Stupid me, again, did the same thing on my wife's mustang too a month later! Same issue there.
LA02MAX's Avatar
Clean your throttle body. I've had a low idle for the past 6 months or so and I just cleaned my TB. Back up to 650 now. (was at 450)
Old Mar 25, 2007 | 03:40 PM
NmexMAX's Avatar
dot dot dot ...
It's about time
SoonerFan's Avatar
Cletus
lesson learned...you shoudlnt change oil
i dont understand how this would effect the throttle
Old Mar 25, 2007 | 03:47 PM
LA02MAX's Avatar
It's about time
I love having a smooth idle again
Old Mar 25, 2007 | 03:52 PM
young1976's Avatar
Those were the only 2 times I did that. Never and havn't forgotten since. I just noticed the idle speed dropped and weird drivability issues. All went away after putting the cap back on.
Oh yea, throttle body cleaning, forgot about that one.
off topic
Oh, and Sooner... I was reading your oil consumption thread, good luck on your next steps and I saw your previous Maxima at Brown Nissan last year when I got my coils replaced under warrenty.
Old Mar 25, 2007 | 04:01 PM
03MAXTNR's Avatar
actually several months ago i had a ses light that came on and took it to the dealer. They said i needed a NEW tps which was going to be 800 dollars installed. So i told them to screw themselves. Is this anything i should worry about. like engine failure or something that will cause alot of damage if i dont fix.
Old Mar 25, 2007 | 04:02 PM
SoonerFan's Avatar
Cletus
looks like you may have found your problem...several months ago.
you need to fix the problem
Old Mar 25, 2007 | 04:03 PM
NmexMAX's Avatar
dot dot dot ...
Not severe engine damage. Might risk going into limp mode which blows booty.
Old Mar 25, 2007 | 04:10 PM
03MAXTNR's Avatar
so if i were to get it fixed then why would they say i need the whole throttle body. i mean dont i need just the sensor.
Old Mar 25, 2007 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
Sensor is integrated into the TB. It's part of the servo motor.
Old Mar 25, 2007 | 04:20 PM
03MAXTNR's Avatar
does anyone know of a website where i can buy the (throttle position sensor)
Old Mar 25, 2007 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
Any place you get the TB
www.car-part.com
Old Mar 25, 2007 | 04:26 PM
03MAXTNR's Avatar
thanks guys
Old Mar 28, 2007 | 11:46 AM
Ahmad_1290's Avatar
i had a low idle But then i cleaned it so now its real smooth, and now i gotta service light. Is that normal?
Old Mar 28, 2007 | 02:41 PM
LA02MAX's Avatar
what method did you use to clean it? Did you move the butterfly plate? If so,
Did you do the ECU reset/ IAVL procedures in the stickies?
Old Mar 29, 2007 | 09:51 AM
03MAXTNR's Avatar
Im supprised there isnt a way to adjust the idle without having to buy a new tb.
Old Mar 29, 2007 | 10:11 AM
SoonerFan's Avatar
Cletus
the sensor is there to adjust the throttle for you...if it isnt adjusting, the sensor is bad and all the advice in this thread applies
Old Mar 29, 2007 | 11:45 AM
NmexMAX's Avatar
dot dot dot ...
I can adjust mine in my driveway +/- 250 rpm. It does require some sort of OBDII software though.
Old Mar 30, 2007 | 08:24 AM
Max_Gator's Avatar
actually several months ago i had a ses light that came on and took it to the dealer. They said i needed a NEW tps which was going to be 800 dollars installed. .
I would suggest that to get effective help around here (and to avoid irritating too many people) that you try providing all of the information you have when you post - instead of making everyone guess what's wrong.
Try this: "The dealer says the tps is bad and will cost 800, here's what the car is doing - is it really tps? And if so, is there a way to adjust the idle to compensate or some other fix?"
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
