5 speed swappers 01 gle w. tcs
Old Apr 14, 2007 | 11:40 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
yes iam looking for all gle with tcs that did the 5 speed swap... how'd u get ur speedo to work!!! for all the others with the knowledge... the autos with tcs DO NOT get their speed signal from the abs... cars with tcs get it from a speed sending unit u have to install on the tranny it self...
heres wat i have done... i have the nissan fast and the automatic tranny and the 5 speed tranny have the same part number for the speed sensor unit. but my problem comes wen i connect it to the existing stock harness... the speedo works but the car still thinks its an automatic, meaning wen i push down on the clutch pedal... the RPM's stay up and take a few seconds to go down, also wen i down shift theres no engine braking.... the RPM's go down only wen i use my brakes...
i was looking at the fsm and i noticed that the speed sensor sends it signal to the TCM (transmission control module) and then it sends a signal to the ecm and the ecm sends it to the speedo AND the TPS (throttle position sensor)
any thoughts???
Old Apr 15, 2007 | 07:52 AM
Kevlo911's Avatar
Kevlo for President
You need the manual ECU because the auto ECU "throttle blips"
Old Apr 15, 2007 | 09:08 AM
KabirUTA13's Avatar
but my car runs fine wen the wires are not connected... and wen the wires aren't connected-- the speedo don't work but the car runs fine
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
Need help
23
Oct 2, 2015 08:56 AM
