Silver G2 Caliper Paint ۞PICS۞
Old Apr 23, 2007 | 02:08 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Like noone has ever seen this before but....
To follow up here from my new rotor and pad thread.
Originally Posted by irish44j
looks good, but you need to put some paint on those calipers, even if it's just some silver or black!
Finally got around to doing it. Was going to pull the calipers off and sand them down and all that mess, had the hardware forever. Instead, got some G2 paint. Still a PIA, took forever.
For some reason my front rotors rust like mad, even though they are new.
Here are some before and after.
Of course, more pics on the Homepage.
Old Apr 23, 2007 | 02:12 PM
Time2go!
Looks good. Not to flashy but not RICE either.
Old Apr 23, 2007 | 02:32 PM
LA02MAX's Avatar
Silver FTW
huffdaddy2008's Avatar
Looks a million times better. Just curious did you take off the entire caliper and bleem em or just tape everything off and paint?
Old Apr 23, 2007 | 02:35 PM
Epacy's Avatar
Thanks.
Left caliper on. Basically only taped off the rubber grommets that holds on the outer bar and used a steady hand. You can see the tape in the pic.
Old Apr 23, 2007 | 02:51 PM
Thats pretty impressive that you didnt tape off everything else. I taped literally half of my car. But I guess since it is silver it wont make as big of a difference as the blue that i used if you got a lil paint on something else.
Old Apr 23, 2007 | 05:44 PM
SoonerFan's Avatar
Cletus
you should have painted the rusty rotor cap while you were at it
Old Apr 23, 2007 | 05:52 PM
Time2go!
Originally Posted by Epacy
Thanks.
Again very nice work.
Is that stuff spray-on or brush-on?
BTW- Painters trick, Use Reynolds Aluminum foil wrap to cover / protect hard to tape spots that you do not want overspray on. Very bendable.
Old Apr 23, 2007 | 06:02 PM
irish44j's Avatar
retired moderator
those new rotors are looking pretty old. Take em off, sand off the rust with emery cloth, and use some high-heat spray paint on the hub area of the rotors.....
Old Apr 23, 2007 | 06:03 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Same thing I did when I installed new rotors to keep the rust level down. Looks good Eric
Old Apr 23, 2007 | 06:16 PM
irish44j's Avatar
retired moderator
I also think you need to apply NISMO decals to the calipers, FTMFW!
Old Apr 23, 2007 | 06:30 PM
Epacy's Avatar
G2 paint is brush-on. I'll remember the foil bit.
Yeah, I will probably end up doing that. Insane how quickly they rust. I have some VHT aluminum that I will use.
Gonna pass on the NISMO stickers, feel'n "GT-R" right now...
Old Apr 23, 2007 | 06:53 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
did that a while back... looks good......IMO the best color for the rotors in a whute car
Old Apr 23, 2007 | 08:15 PM
Mints33's Avatar
Are those 245s? They look a little narrow on those wheels.
Old Apr 24, 2007 | 12:25 AM
djbonsu's Avatar
Originally Posted by LA02MAX
Silver FTW
are those custom lettering or caliper covers? sh*t is hawt!
Old Apr 24, 2007 | 01:18 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Old Apr 24, 2007 | 07:13 AM
Epacy's Avatar
They are 245's.
What is this "narrow" bit?
Old Apr 24, 2007 | 08:53 AM
MaxBoost925's Avatar
Drug Money
They are 245's.
245 on a 7 inch wheel = falls off while cornering.
Old Apr 24, 2007 | 09:06 AM
LA02MAX's Avatar
They're stickers...forgot where I got them from, but a lot of people are using them. And I have the 6th gen front brakes, so I'm not sure how well these would fit on the smaller 5.5 gen calipers. Thanks for the compliment!
Old Apr 24, 2007 | 09:57 AM
Epacy's Avatar
your statement =
Old Apr 24, 2007 | 09:59 AM
Drug Money
your statement =
Were you talking about putting a 245mm profile tire on a 17x7" stock wheel?
I simply said by doing that, you're putting the tires at risk of falling off the wheels while cornering.
Old Apr 24, 2007 | 10:17 AM
LA02MAX's Avatar
He has MM Evo5s...
Old Apr 24, 2007 | 10:31 AM
Drug Money
He has MM Evo5s...
oic
Old Apr 24, 2007 | 01:29 PM
Epacy's Avatar
oic
The pictures never lie.
Old Apr 24, 2007 | 02:11 PM
Jess's Avatar
SHIFT_In2D
Looks really nice I might have to do that myself sometime. Awesome job!
Old Apr 24, 2007 | 02:12 PM
shurik's Avatar
Epacy when did you get H-techs? I though you were dropped on Eibachs! Well anyway's good job on painting the calipers! I did mine the same color around 3K miles ago!
What new rotors did you go with anyway? Rusty...
Are those rotors OEM ones or what? They're designed completely different, no cooling spots or anything, just one whole peice!
Old Apr 24, 2007 | 03:58 PM
LA02MAX's Avatar
He got them before I got mine which was well over a year ago...
And epacy, next time try buying some zinc plated rotors. A full year now with my setup and no rust
Old Apr 24, 2007 | 05:27 PM
Epacy's Avatar
I have had H-techs for about 2.5 yrs.
Check the brake link I provided in my original post, it'll explain what rotors I have.
Old Apr 24, 2007 | 09:59 PM
DonGfun's Avatar
VW = 30 MPG
I like white on a white car.
Old Jun 8, 2007 | 01:42 AM
Jess's Avatar
SHIFT_In2D
Resurrecting the thread...
I just wondered how your calipers have stood up after being painted. Wonder if the rust has already taken its toll.
Just need some pics before I do this
Old Jun 8, 2007 | 04:37 AM
burnurass's Avatar
Just do it!!!! It's really easy. The hardest part is masking off the brake area.
Mine in black.
Old Jun 8, 2007 | 08:53 PM
TorridoMax's Avatar
i picked up a duplicolor valiper paint kit i find it coats alot heavier than the g2 paint also it dries nice n hard, i used the g3 before and after 3 coats i still seem the sandy finish of the caliper with the dupli-color stuff it coats pretty heavy.. this time ill be doing mine silver and prolly gonna take off the whole caliper one by one and paint them...
Old Jun 8, 2007 | 09:38 PM
Epacy's Avatar
I'll try to get some this weekend. Been busy trying to get the rest of the car in order. Put on some new things.
Calipers still look as good as new.
Old Jun 9, 2007 | 08:59 AM
SoonerFan's Avatar
Cletus
painted mine black a few months ago and the paint is still perfect. it looks and feels like i just painted them.
painted
sticker just put on
Old Jun 9, 2007 | 01:57 PM
wyche89's Avatar
epacy, those calipers look good.. i was thinking about doing mine the same color and painting the rotor hub black to get rid of the rust look.. and yeah i feel you on that rust issue by the way.. mine started to rust after the first rain we got.. i was so upset.. i started a thread on here trying to find some product that u could use pesides paint to prevent rust, but no luck.. im gonna have to paint mine.. i like those rims too
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
