Disable High Beams, installed a HID kit...
Old Jul 11, 2001 | 08:06 PM
BigDogJonx's Avatar
Hi, I just installed an HID kit and know that on the 2001 when you cut on the high beams, the low beams cut off.
Is there a way I can disable this relay? Because I do not want to by accidently use the high beam to "flash" someone and then screw up my hid lights.
Dixit
Old Jul 11, 2001 | 08:14 PM
AznWontonboy's Avatar
Dixit
im sure you'll be fine. my bros bmw 328i has no problem with the on/off thing. not a problem with his xenons yet. how will you screw them up?
Old Jul 11, 2001 | 08:30 PM
BigDogJonx's Avatar
You can screw them up in a way like if you were to flash someone quickly with you high beams, the Ballast gets turned off and turned back on also at the same time. Most ballasts have a protection that if it clicks on and off too many times in a given time, it will remain off until for 1min or so.
I had this happen in my Millenia
Dixit
cruce91
Sep 20, 2015 10:23 AM
litch
Sep 5, 2015 11:29 AM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
