P1706 Park/Neutral Position switch... on a 5spd??
Old May 5, 2007 | 10:42 AM
Yayomax's Avatar
still brewin'
'Sup peoples! First a question. Do our 5.0 gen ECU's store more than 4 codes at once? About a year ago, my SES indicator came on. There were 4 codes for the infamous P0430/420 issue. I just said f*#k it until I got a y-pipe and o2 sim. About a month after that, my gearbox was changed cause it was leaking real bad. Fast forward 9 months later, I got the codes read and yes there were 4 codes related to 430/20. When I installed the sim and reset the ECU, 45 miles later the sob comes back on. This time with the P1706. I believe it was there when my gearbox was swapped out, which leads me to my initial question. Ok, sorry for all the wind, now the real issue. But isn't a PNP (park/neutral position) swith related to an automatic only? My bachup lights haven't worked since either.
Old May 5, 2007 | 10:43 AM
Kevlo911's Avatar
Kevlo for President
Neutral safety switch on manuals tell the car if it is in neutral or in reverse.
Old May 5, 2007 | 10:58 AM
Yayomax's Avatar
still brewin'
Oohhhhhhh. so where is this sensor located. Will it work if the gearbox is not grounded correctly?
Old May 5, 2007 | 11:00 AM
Kevlo911's Avatar
Kevlo for President
It is located on the transmission.
Go to www.phatg20.net and download the FSM for your car, it will have pics and a description for all the sensors.
Old May 5, 2007 | 11:13 AM
Yayomax's Avatar
still brewin'
Thanks abunch, I'll do just that. any idea about the reverse lights?
Old May 14, 2007 | 11:50 AM
AcidJake75's Avatar
if you replace that switch - your reverse lights will start to work again - I was having the same issue. I accidentally broke that switch ( I have a 5spd too) and had to replace it. Reverse lights have been fixed since.
gavin68
Sep 18, 2021 12:36 PM
ef9
Oct 4, 2015 08:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
