Gutting intake manifold
Old May 13, 2007 | 06:53 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I've seen some people mention it, but that's about it. Since I'm doing an engine swap (and I have time), I'd like to get a little info. about this. If it's practical to do (for a moron like me haha), I'd like to try it since I hear the gains are pretty good. Intake and exhaust are going on with the engine and I want to do w/e mods I can before it's all assembled.
Old May 13, 2007 | 07:52 PM
SoonerFan's Avatar
Cletus
"gutting" usually refers to removing the variable intake mechanism. you will get high end gains but lose a lot of low end (which is why nissan designed it that way)
Old May 13, 2007 | 08:00 PM
Bad *** Newb
well, considering how much torque she already has in 1st, I'm not really concerned with that I guess. I shift at redline 90% of the time, so I doubt I'll notice that low end missing lol.
Old May 13, 2007 | 08:03 PM
SoonerFan's Avatar
Cletus
then its easy, remove the IM and remove the butterfly valve (similar to the TB)
Old May 13, 2007 | 11:55 PM
platinum03SE
so how much of a gain would you expect?
Old May 14, 2007 | 12:50 AM
Bad *** Newb
a few I guess, more than 1 and less than 15 haha
I don't know, just sounded like a good idea to me. I'm all about more airflow
I bought a weapon R intake, so I'm hoping the filter is as good as they say (I know the quality probably sucks, but as long as it lets a bunch of air in), since that should allow for optimum flow with the manifold open.
Old May 14, 2007 | 12:57 AM
LA02MAX's Avatar
Removing the power valve alone will do very little if anything at all....something else is required.
Old May 14, 2007 | 12:58 AM
Bad *** Newb
Originally Posted by LA02MAX
Removing the power valve will do very little if anything at all....something else is required.
boring the **** out, so it's a larger diameter?
That can be done if I can find the right tools.
Old May 14, 2007 | 01:02 AM
LA02MAX's Avatar
Something known as 'port matching' will help, I guess...But it's a PITA to do as you have to be very meticulous...it takes forever.
Look at this thread. Namely Post #24.
http://forums.maxima.org/showthread.php?t=520614
Old May 14, 2007 | 01:18 AM
Bad *** Newb
yeah, thanks, that's what I was looking for. I guess I didn't use any of the rights words when searching
Old May 14, 2007 | 07:49 AM
02Maximan's Avatar
I bought a weapon R intake, so I'm hoping the filter is as good as they say (I know the quality probably sucks, but as long as it lets a bunch of air in), since that should allow for optimum flow with the manifold open.[/QUOTE]
I know this is a little off topic but I'll have to say that just letting a lot of air in isn't always a good idea. Get something of more quality, something you can trust to keep your engine clean. Their foam filter is cheap. Its extremely easy to overoil and the plastic lip of the filter that the coupler clamps to gets soft and bends when you clamp the brace in it, thus creating a small air leak. I am much more satisfied with my AEM dryflow than that POS.
Old May 14, 2007 | 11:19 AM
opanick's Avatar
your talking about cutting out the shelf inside of the manifold correct??? I know a guy on the alitma forums did it, ill get the link with pics when I get home
Old May 14, 2007 | 11:23 AM
Puppetmaster's Avatar
There's also a link to that discussion in the thread that LA02Max posted....
Old May 14, 2007 | 11:26 AM
LA02MAX's Avatar
Yes I am. The link I posted earlier (and the post I noted) has pictures of it.
Here's the thread you're talking about: http://www.nissanclub.com/forums/eng...uestion-2.html
Old May 14, 2007 | 12:39 PM
Bad *** Newb
I figure the foam will degrade and be crap in a couple months, but it'll have to do till then. Engine + upgrade parts = One broke SOB that was already broke to begin with haha
I'll worry about a good filter then.
Old May 14, 2007 | 02:22 PM
Theyears02's Avatar
what foam?
Old May 14, 2007 | 02:56 PM
knight_yyz's Avatar
Toolie
i'm halfway thru port matching my spare upper IM. Hopefully it will be done this summer. I'm keeping the valve and not removing the shelf. Just stock with matched ports. I'll see how it works late summer
Old May 14, 2007 | 03:24 PM
Theyears02's Avatar
i think gutted with aaron's spacers is the way to go. gutting obviously adds major high range, and the spacers dyno'd a fair increase in the low end, so you would end up with equal or more low end and a bunch more top end...especially if you have extended rev limit
Old May 14, 2007 | 06:25 PM
inspiredbykev's Avatar
You should thank my D***
I have a spare intake manifold. Pm me if your interested or check here
http://forums.maxima.org/showthread.php?t=520082
Old May 14, 2007 | 07:29 PM
Bad *** Newb
I will also have the '05 manifold that comes with my new engine, and I'd like to use that (plus it would be easier for me to strip off and work on it, since my car is sittin at the shop).
Of course I'm gonna get told just to swap my old one on it and read the ****ing FSMs lol. Sorry, but me too weetarded to make heads or tails of some of that stuff when trying to compare.
Thank You, that helped immensely, there's enough info in there for me to do it.
I don't have an A/F controller, I'm interested to see how all this rigged **** runs haha w/o one. I'll get one when I scrape enough cash together. Perhaps then I will dyno and tune it. With that crap and hopefully an underdrive pulley, I hope to make you guys jealous of my rigged POS car's WHP lol.
Old May 15, 2007 | 06:19 AM
NmexMAX's Avatar
dot dot dot ...
I hope you get a abseline dyno before you dyno the porting.
Would still like to see a DJ dyno on these.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
