Drivers Side Power Window Auto Switch
Old May 15, 2007 | 07:11 PM
drock02's Avatar
I did a search, but didn't find anything like what I'm seeing on my max. My 02 drivers power window auto up and down function doesn't work. I can push and hold to make the window go up and down, but can't push once for the window to auto up or down like the passenger side. Is this a simple reset or switch issue?
Old May 15, 2007 | 10:02 PM
bvenvert's Avatar
You will need to replace the switch. I had an issue with the driver's side auto window switch on my 2000 and it resulted in a power window motor replacement. I was having intermittent problems with the auto switch and one day I used it to put the window up...too bad the switch malfunctioned and didn't shut down the power window motor. About $550.00 later it was fixed. Fortunately it was covered under an extended warranty.
Might want to replace the switch when you get a chance.
fastcarny
May 18, 2020 10:40 AM
mpbclutch33
Aug 21, 2015 06:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
kjm900r
Aug 5, 2015 07:14 AM
