How long did(have) your Illuminas last(ed)?
Old May 21, 2007 | 09:03 AM
number2jcb's Avatar
I have the Eibach/Illumina set up with 2f/3r. I put them on about 20k and my car is bottoming out and floating like a buick. I live in the NYC area so roads aren't great. I was just curious if mine are abnormally low, or if that is what other people are finding with the lowered setup.
Old May 21, 2007 | 09:26 AM
ManUtd18's Avatar
I bought mine used with about 40k mile on the and I haven't had any problems. Something may be wrong with yours, but I'm not sure.
Old May 22, 2007 | 05:16 AM
djfrestyl's Avatar
Suspension Yoda
Been running on Progress 3F/4R for 50K+ miles without an issue.
Old May 22, 2007 | 05:32 AM
zoner's Avatar
The roads around here (raleigh) are probably a little better than around New York, but I've put 80+K on mine with no problems. Have you tried cranking the settings up to see if that helps?
Old May 22, 2007 | 08:06 AM
OOmaxSE's Avatar
I put about 4k mi on my set and I suspect that my front passenger is blown. I'm on progress which could be the reason (1.7fr and Illumina's say good for 1.5in drops). I've also hit a plethora of enormous pot holes...
Old May 22, 2007 | 09:31 AM
ManUtd18's Avatar
That probably why. You are on progress springs which sit the car really low and you also have bad road which doesn't help. If I were you I would look into Eibachs or another type of spring that still gives you a good drop, but not too low to the point where you are hitting potholes everywhere you drive.
Old May 22, 2007 | 09:39 AM
00MaxSE's Avatar
Pointy Elbows
No problems here. Progress springs. No pot holes.
Old May 22, 2007 | 09:46 AM
NiSmOVQ35's Avatar
my old setup was H&R springs and illumnias on my old max, the illumnias lasted me close to 30k...also in ny.
Old May 22, 2007 | 10:31 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Had mine for over 40K and no issues. A little rust on them but no squeaks or bouncing.
Old May 22, 2007 | 05:08 PM
00MaxSE's Avatar
Pointy Elbows
No rust here.
Old May 22, 2007 | 05:30 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
how could you test to see if they are blown? mine seems to slip a little when i go over bumps on a turn (slight one or full on 180 degree turn) esp on the freeway it seems like the car likes to follow bumps. but i've had mine for about 35K on h-tehcs.
Old May 22, 2007 | 05:54 PM
00MaxSE's Avatar
Pointy Elbows
Check to see if there is hydraulic oil leaking out.
Old May 23, 2007 | 05:34 AM
kukx30de's Avatar
I blew both rear illuminas within a month of installing them.
I was using them with stock GLE springs.
I would not blame the illuminas though. I found out my GLE had the softer springs that were prone to bottom out causing the shocks to blow.
Since switching over to H&R and illumina's about 10K miles ago all is well.
Old May 23, 2007 | 09:00 AM
NisMo-Max's Avatar
stechs with illuminas, dont think i have any problems, had them for about 25k miles... and there is potholes everywhere in California.. haha
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
