Axxtion STS installed w/ poly bushings, OMFG why did i wait so long
Old May 24, 2007 | 06:34 PM
MyBlue02's Avatar
see this
http://forums.maxima.org/showthread.php?t=522176 both places had lightning fast shipping 2 days max from buying them
this is right up there with the rear sway bar as far as i am concernedm what a drastic diferance, from sloppy feel (oe bushings were shot at 50K) and nice tight short throw.
only thing is what every one else seems to say...getting used to kinda slaming (not realy slaming, just more effort) over and down to reverse.
this also got rid of the engine movement feed back i was experiancing...now for lower motor mounts
Old May 24, 2007 | 07:40 PM
Gle03Max's Avatar
Thats great to hear..... i think you made my mind....
one quick question, is the shifting really "stiff" and like harder to shift or still smooth like factory?
Old May 25, 2007 | 08:45 AM
MyBlue02's Avatar
there is a nylock nut tighten on the actuall shifter rod in hte car that you can make tight and stiff...or just like stock...mine is just like stock.
Old May 25, 2007 | 10:35 AM
SoonerFan's Avatar
Cletus
it is a little stiffer but thats good. the stock throws are sloppy with a lot of play. with the bushings its stiff and precise...you know its going in to the gear.
and reverse is hard...my girl has to use both hands (to put the car in reverse)
Old May 25, 2007 | 12:42 PM
2kSC's Avatar
"is hard...my girl has to use both hands" ....lol....mine does too
Old May 27, 2007 | 07:21 AM
MyBlue02's Avatar
mine is as easy to move as the stock set up was...its just crisper, again...i played with the tension of hte nylock ny like puppetmaster siad in his write up http://forums.maxima.org/showthread.php?t=455387 and it is as easy as stock.
you just need to be fast with a little more than normal effert for reverse...no complaits here.
Old May 27, 2007 | 08:22 AM
maxspeed96CT's Avatar
The original VQ...
Would this help with the 3rd gear crunch alot of us are getting?
Old May 27, 2007 | 08:44 AM
NiSmOVQ35's Avatar
Yes..... it helps a bit.
Old May 27, 2007 | 08:57 AM
MaximusMorpheus's Avatar
I still think that the throw on the homemade STS is shorter then something like this. I purchased a STS like this and went back to the homemade version because I thought the throw was shorter.
Old May 27, 2007 | 10:15 AM
pbn85's Avatar
the STS or the shifter bushings?
SoonerFan's Avatar
Cletus
bushings.....
Old May 27, 2007 | 10:22 AM
pbn85's Avatar
yea thats what I figured...hmm I took advantage of Brian's weekly sale and got them for $26 I believe but never got them installed. Not to jack the thread, but how much should they cost to install?
Old May 27, 2007 | 06:56 PM
MyBlue02's Avatar
um, install them your self...rather easy if you have some skill
Old May 27, 2007 | 07:53 PM
SoonerFan's Avatar
Cletus
install is very easy...they come with instructions.
Matt93SE
May 24, 2019 02:58 PM
Johnny9595
Aug 21, 2015 09:18 AM
Wolvee
Aug 11, 2015 12:24 PM
egali045
Aug 5, 2015 09:02 AM
00 Max
Aug 4, 2015 07:09 PM
