resetting sunroof
Old Jun 1, 2007 | 10:54 AM
Burton's Avatar
resetting sunroof
I know the way to reset if it is stuck open, is there a way to reset when it is closed , I have a 2003 and it has the slide switch. I changed battery on car and now it does not work
thanks Doug
Old Jun 1, 2007 | 01:21 PM
Madsci's Avatar
its stuck closed and neither the slide or tilt options work? Or just the slide?
Old Jun 1, 2007 | 03:00 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Just hold the tilt button in the forward position with the car on. You'll here it make the click or shift sound. Then your set. After it makes the sound then try the slide feature.
By the way it's in your owners manual.
Old Jun 1, 2007 | 04:33 PM
SoonerFan's Avatar
Cletus
if only car companies made owners manual's for car they produce
Old Jun 2, 2007 | 10:08 AM
Burton's Avatar
ok tested motor and it is kaput. and the owners manual is only if it is stuck open.
Old Jun 2, 2007 | 11:23 AM
SoonerFan's Avatar
Cletus
no its not.
if you disconnect the battery, you have to reset the switch. the procedure is the same no matter where the sunroof is.
Old Jun 2, 2007 | 03:27 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by soonerfan
no its not.
I've never had to reset my switch, isn't that vierd *crazy dutch bastard accent*
Except for the time it refused to open for no reason, and I had just used it too. Crazy *** electronics.
Old Jun 3, 2007 | 07:51 AM
ghostrider17's Avatar
no its not.
Mine did this...and as usual, sooner's right.
Old Jun 25, 2007 | 01:39 PM
Neapawn's Avatar
This can be a real pain make sure to test for leaks!!!!!!!!!
Old Jun 25, 2007 | 01:40 PM
Neapawn's Avatar
It is probably an electrical problem which can stem from anything to the fuse to being off track or the motor
bigdogsteve
Jan 31, 2018 04:18 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
