Cleared headlight lens question
Old Jun 10, 2007 | 08:50 AM
Swisscheese's Avatar
Anyone that has done this, the walkthrough says to buy a clear lens from home depot or a frosted lens from tap plastics.
My question is, was anyone able to find exactly what they needed at home depot. What size and where was it. I cannot take my headlight apart yet to measure and test size, but I want to go ahead and buy the clear lens.
Just let me know what exactly you bought from home depot.
Old Jun 10, 2007 | 09:11 AM
NismO2max's Avatar
Ha. I just did this tedius job yesterday actually. I bought the Malibu's like the walk thru told me to. Those Tap Plastic ones would be your only exact fitting lens, but they're frosted and I figured it wouldnt look right.
To answer your question, the best thing to get is the Malibu's and cut em up. Just make sure you have a Dremel or you're screwed.
Old Jun 10, 2007 | 09:31 AM
TorridoMax's Avatar
yes home depot does have the malibus they are in the lighting section usually where they have the outdoor replacement lenses and bulbs.. they are in a bag thats white on one side and clear on the other, usually stuffed in a box... GL
Old Jun 10, 2007 | 09:48 AM
huffdaddy2008's Avatar
http://forums.maxima.org/showthread....+blinker+lense
Old Jun 10, 2007 | 01:58 PM
MyBlue02's Avatar
there are no more "malibu" ones around here they are all now "yardscape" and hte same as malibu.
Old Jun 10, 2007 | 02:52 PM
monty31's Avatar
http://forums.maxima.org/showthread.php?t=514136
Old Jun 11, 2007 | 06:54 AM
MaximaPolak's Avatar
or you can just leave the lense out and it looks just as good.
Old Jun 11, 2007 | 09:05 AM
replicant's Avatar
Polak that actually looks really good; nice wheels btw. i love majestic blue :/
Old Jun 11, 2007 | 09:10 AM
Prophecy99's Avatar
Polak /or anyone else!! any night pics of these (no lense replace) headlights??
IM very curious as to it would be probably 1/2 the time to do this clear out.
Old Jun 11, 2007 | 11:09 AM
replicant's Avatar
No doubt, I'm actually considering returning my malibu lenses back to home depot and going no lense at all. Then again I could just go ahead regardless, if I'm going to have the unit opened up one way or the other, might as well just put the clear lense on there for that added protection (just in case i suppose).
Old Jun 11, 2007 | 03:00 PM
Tippy Toes's Avatar
Has anyone done any Halo rings around both the actual lights and even possibly the fogs? If so how can I find the parts to do this mod? I also need to clear the yellow blinker. Which bulb is it from autolumination. Thanks in advance.
Tippy Toes
Old Jun 11, 2007 | 04:56 PM
Anachronism's Avatar
Are you lookinng at housecor's how to? -- http://www.innerbean.com/housecor/clear_HIDs.html
He has a picture of the exact light you need, malibu ML11P2. They are in the outdoor lighting section. They are not the exact size, you have to trace the orange lens on them then cut out a piece. You may have to try more than one store. I found A set at my local Home Depot last week, my angel eyes arrived today . Hopefully I will have a chance to install everything in the next couple of days.
Old Jun 11, 2007 | 06:05 PM
replicant's Avatar
same here. my angel eyes, progress rsb, and clear corners arrived today; christmas in june!
Old Jun 11, 2007 | 08:21 PM
Squirrel82's Avatar
Im thinking about clearing my headlights and painting them body color.
Old Aug 1, 2007 | 12:46 PM
Trurida18's Avatar
MAAAAN! i cant find the damn clear malibu lenses, I went to two home depots, and called 2 others. Is there any source where i can order them online for something????
Old Aug 1, 2007 | 12:56 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
You do know you don't have to use the Malibu one right? So long as it's a plastic lens that is oversized then you can use it. Just cut it to shape. Seal it in place and your straight. Juts make sure the lens is a little concave so it gives you that affect. However, it's not a must so whateva.
Squirrel: DO IT!!!
Old Aug 1, 2007 | 01:06 PM
Trurida18's Avatar
^^ok, do you have a suggestion on what i could use to substitute, if not..........then i need the malibu lenses. Simply because thats what every one has used and ITS KNOWN to work perfectly (well almost perfectly with no problems)
Old Aug 1, 2007 | 01:18 PM
Orgullo's Avatar
Go to HD, look in the lighting section. So long as the lenz is oversized then you can use your dremel to cut it down to size. Make sure to get some apoxy because you are going to seal it back in place. There is a small lip on the inside for your new cover to sit so you'll have the room to put the apoxy without it being seen.
I found some off of a curve light. Usually used for the walk way lighting. It worked out great for me.
This may sound funny but you can use the plastic cover from the lamps or ceiling fans. They are large enough and you can get both out of one.
Old Aug 1, 2007 | 03:10 PM
Trurida18's Avatar
thanks, i guess worst case scenario, ill have no choice but to do the suggested...thanks alot bro
Old Aug 1, 2007 | 03:49 PM
Jess's Avatar
SHIFT_In2D
If anyone wants clear "Malibu" lenses I can purchase & cut them out for you to send em your way. I've done the headlight mod for myself, aNdyMan and LeX.
My work is good so shoot a PM my way if needed.
My car for Example: (excuse the dust lol)
BTW Swiss did you get those lights done yet?!?!
I'm always available to help out a local
Old Aug 1, 2007 | 04:35 PM
pimpin02max's Avatar
I am thinking about clearing my headlights and painting them black or just leaving them silver but I have one question, after you put the headlight back together do you need to put some more glue or silicon on??? Housecor's site says just use channel locks to assure a tight seal so I am confused, a buddy of mine used silicon and his headlights look like crap...
Old Aug 1, 2007 | 04:45 PM
Jess's Avatar
SHIFT_In2D
After putting it back together. Bake it for a small amount of time say 5-8 mins. To warm the glue up again. Take a few clamps and clamp it to ensure a tight seal.
I've seen work done with silicone and yes...doesn't look pretty haha. Someone here actually still had condensation on the lense. So I with that, I would use the above method.
Old Aug 1, 2007 | 05:03 PM
Teufelhunden's Avatar
yea, after putting my headlights back after clearing them, they were fogging after a few days. so i baked them again re opened and cleaned the inside since there were some water marks. put the silicone sealant and they never leaked or fogged again. so its better to put them on so it doesnt leak in the future. its kinda sloppy, but you cant see them when the hood is closed, and its clear so its not that bad.
Old Aug 1, 2007 | 06:39 PM
Squirrel82's Avatar
They dont sell just the lenses.Its a bag of two lightbulbs which you have to pry the plastic lense off the light bulb..I found it in the college park home depot off Rt1.It was in the outdoor lightning section.
My lights were fine for a couple of weeks until the day of a meet around here.I washed it in the morning getting ready to go and my passenger light fogged up like crazy.I stuck a heat lamp on it to get the moisture out.After that I ran a small bead of clear silicone all the way around the seams of both lights and no ploblems.Its not visible from outside.
Orgullo,that was posted before I sprayed them black.
Old Aug 1, 2007 | 08:23 PM
Trurida18's Avatar
HEY I WANT A SET of your malibu lenses.......ILL DEFINATELY PAY YOU....
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
