so...my max wont rev past3500 rpm help?
Old Jun 12, 2007 | 02:47 PM
DragdMax's Avatar
so im makin a lane change on the freeway when my car jerks abruptly.i was probably at 5k rpm
ever since i cant go past 2500 rpm.
can somebody tell me whats wrong?
oh and i meant 2500 not 3500.
sorry and thanks in advance.
Old Jun 12, 2007 | 02:52 PM
magdocjr's Avatar
Can you tell us why you did not search for the answer first? There are only about a thousand threads saying the same thing.
IBMAFistoldtoyouonehundredtimes
Old Jun 12, 2007 | 02:54 PM
DragdMax's Avatar
allow me to clarify.
i did search.
the poor man search isnt as great as everybody thinks it is.
im a newb to computers so be easy.
Old Jun 12, 2007 | 02:56 PM
Kevlo911's Avatar
Kevlo for President
http://www.google.com/custom?hl=en&i...ums.maxima.org
Searched that
http://forums.maxima.org/showthread.php?t=334762
Clicked that
I think the maf problems are in the Stickies, so always look there for problems first.
Old Jun 12, 2007 | 02:58 PM
DragdMax's Avatar
thanks for your input kevlo
Old Jun 12, 2007 | 03:09 PM
Stardust's Avatar
F---ing Kangaroos
i did search.
Old Jun 12, 2007 | 03:32 PM
DrunkieTheBear's Avatar
Turbo'd Saab
Originally Posted by Stardust
agreed. i do just fine with the free search
Old Jun 12, 2007 | 04:02 PM
mist max2000's Avatar
^^^ he blamed it on computer illiteracy lol,... prob didnt search through the fourms and only search through google,.. either way.. research up some MAF threads...
Old Jun 12, 2007 | 04:07 PM
MaximaGT-R's Avatar
I'm a Happy Man!
your problem is maf
Old Jun 12, 2007 | 04:10 PM
theoutsider's Avatar
Blown maf...Busted mine last week....Exact same symptoms..
Old Jun 12, 2007 | 04:16 PM
Important...Do NOT buy a new 2002-2003 MAF.
Read this first and read it entirely...youll save 3-400$
http://forums.maxima.org/showthread.php?t=348395&page=3
Old Jun 12, 2007 | 04:17 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
replace your MAF....
Old Jun 12, 2007 | 05:28 PM
DragdMax's Avatar
post *****.
Old Jun 12, 2007 | 05:29 PM
DragdMax's Avatar
so quickly is the maf something that warranty will cover?
Old Jun 12, 2007 | 05:30 PM
Kevlo911's Avatar
Kevlo for President
Ask your dealer...
Old Jun 12, 2007 | 05:58 PM
nk2k2's Avatar
question about using the a 2k1 maf on a 2k2, i know you have to transfer over the thermister but how does that work exactly? i was looking at the pictures in the maf thread in the how-to section but it kinda of makes sense to me. I want to make sure i know this well so i can fix my car quickly if im stuck.
is the thermister the silver wire that is attached to the two metal points?
Old Jun 12, 2007 | 07:59 PM
ive pulled my MAF out like that one is before and i know i dont have that silver wire between mine,.. and ive had 2 MAfs, . . .(2000 and 2001)
Old Jun 14, 2007 | 06:31 AM
nk2k2's Avatar
can anyone chime in on the thermister issue?
Old Jun 14, 2007 | 06:36 AM
NmexMAX's Avatar
dot dot dot ...
You transfer the thermistor from your busted 2k2, into your NEW 2k1 MAF.
Because 2k1 MAF's do not have it, but thay DO have the 2 clips that will allow the new thermistor to be attached to.
Old Jun 14, 2007 | 07:09 AM
nk2k2's Avatar
so the thermister is that silver wire?
Old Jun 14, 2007 | 07:22 AM
NmexMAX's Avatar
dot dot dot ...
Yes . . . . . .
Old Jun 14, 2007 | 08:12 AM
Redstone's Avatar
I had the same problem about 10 months ago and before I had any codes pulled most people on the org told me it was possibly the MAF. I replaced my MAF with an 01 MAF and I did the IAT swap and I still had the same problem. So I went to the dealer had the codes pulled. A P0650 came up. This was definitely not the MAF, but the ECU. My car was doing the same thing you described and if I am correct then your car in "fail-safe mode" and your engine won't rev past 2500 rpms. Bottom line is that I had to replace the ECU. Before you go and buy a MAF check the codes first to see what the problem is. That's my best advise.
If it turns out that your problem is the MAF then follow the advise some of the org members posted above and buy the cheaper 01 MAF swap the IAT and save some $$. Good luck.
Old Jun 14, 2007 | 12:47 PM
DragdMax's Avatar
thank you for your input redstoe. ima head down to the dealer right now and have m car checked out.....
Old Jun 14, 2007 | 10:54 PM
steven88's Avatar
Need A Light?
but then whose gay u know?
Old Jun 14, 2007 | 10:56 PM
The Law's Avatar
I R The Law
maxboost?
Old Jun 14, 2007 | 11:07 PM
steven88's Avatar
Need A Light?
Originally Posted by The Law
maxboost?
ahh, indeed
Old Jun 14, 2007 | 11:14 PM
The Law's Avatar
I R The Law
ahh, indeed
I see
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
JoshG
51
Sep 21, 2015 10:41 PM
