Engine Replacement...
Old Jun 22, 2007 | 10:06 AM
Chaka's Avatar
Zulu
I recently had my engine replaced by a local mechanic. He bought a fed emission engine without knowing my car was cali...after he finished mounting the engine he realized they were a bit different...exhaust manifold, swirl control valve actuator, and the vaccuum hoses on top of the intake manifold.
He went a pulled the vacuum hoses and the exhaust manifold from the old engine. Now we can't find the swirl control valve actuator...i got these error code after he started the engine...
P1130....due to the swirl control valve i guess
P1320 and P0303...i'm guessing bad coil
P0135...bank 1 oxygen sensor.
what should i do?
take the engine out and return it?
find a cali spec intake manifold?
Plug the swirl control valve hose and ignore it?
Old Jun 22, 2007 | 07:57 PM
oldngivout's Avatar
Willing to learn
I think that you should do NOTHING. I have exchanged several engines for people, and not once have I delivered one to a customer with a CEL, SES or other issues that would keep it from running correctly or passing emissions testing.
Sorry for your mechanic, but he owes you a properly operating vehicle, unless you had some prior arrangement to accept anything less.
Old Jun 23, 2007 | 10:20 AM
KRRZ350's Avatar
0q3454325
Old Jun 23, 2007 | 03:55 PM
pmohr's Avatar
No more Maximas...
Why not just pull everything you need from your old motor?
Old Jun 24, 2007 | 10:24 AM
Chaka's Avatar
Zulu
cuz the mechanic was stupid enough to return the core before mounting.
Old Jun 24, 2007 | 10:58 AM
Kevlo911's Avatar
Kevlo for President
Well tell him to find you a cali spec front header, upper/lower IM and you will be set
Old Jun 24, 2007 | 01:45 PM
Chaka's Avatar
Zulu
i was able to get the exhaust manifold...only thing i'm missing is the lower intake manifold...
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
