nissan rebuild motors
Old Jun 29, 2007 | 08:56 AM
Maximum Performance's Avatar
well my motor is burning oil, 2.5 quarts in 1600 miles, so nissan ordered a new motor for me
how are the new rebuild motors holdin up for you guys?
any issues with burning oil again?
Old Jun 29, 2007 | 09:03 AM
pbn85's Avatar
your not getting a rebuilt motor...its remanufactured, meaning its a new motor. I got my new one b/c of oil burning. 1300 miles on the new one and not a drop of oil lost. They choose to replace the engine b/c a rebuilt is too timely and costs more for them
Old Jun 29, 2007 | 09:14 AM
KRRZ350's Avatar
A remanufactured motor is one that was rebuilt by nissan, it is still a rebuild, just not by the dealer.
Old Jun 29, 2007 | 09:31 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
remanufacture is the same as rebuild...... same as refurbished
Old Jun 29, 2007 | 09:55 AM
pbn85's Avatar
no actually its not a rebuild...its a brand new engine, other wise it would be called a "rebuilt" engine. I know for a fact mine was brand new...even Nissan of USA confirmed that as well as the dealer. From what they told me, they dont rebuild engines anymore but they still make new engines for cars out of production.
Old Jun 29, 2007 | 09:57 AM
STILLENGLE's Avatar
talk to soonerfan he had his down a little while ago he would probably know best.
Old Jun 29, 2007 | 10:01 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Greg, I would just sell the POS before it starts to burn oil again. Still worth some $$$, but I dunno what I would get if I was in your shoes.
800-NISSAN1 and grill them bout giving you 100K mile warranty on powertrain just like they did on all the 06 Altimas when the QR motors where recalled.
Old Jun 29, 2007 | 10:17 AM
Gle03Max's Avatar
Remanufactured=rebuilt=not new.
No matter how you look at it its a rebuilt motor. Whether done by dealer or Nissan USA.
For the person who said there's was new- I aint saying yours isn't because I don't know if there are different mileages that they might use remaned or new. But if they said remaned it is rebuilt.
Old Jun 29, 2007 | 10:51 AM
SoonerFan's Avatar
Cletus
Originally Posted by SLVRMAXX
your not getting a rebuilt motor...its remanufacture, meaning its a new motor.
"manufacture"- To make or process (a raw material) into a finished product, especially by means of a large-scale industrial operation.
"re" - Prefix (re-): means "back" or "again"
"remanufacture" - to make AGAIN
Old Jun 29, 2007 | 10:52 AM
SoonerFan's Avatar
Cletus
Rebuilt Vrs. Remanufactured Parts
Especially Engines
By Glenard Munson [Learn More]
There is a significant difference between REBUILT and REMANUFACTURED parts when you are considering a repair for your vehicle. Many people erroneously believe the two terms to be synonymous, where they actually refer to two different processes.
In addition, many states, such as California, require re-registering and/or re-titling of a vehicle when it has received an engine replacement, since the "facts" included in the VIN (Vehicle Identification Number) would mis-matched unless the information is corrected with the Department of Motor Vehicles.
Any part that is NOT "OEM" (Original Equipment Manufactured), falls under one of four categories:
1. NEW replacement part, non-OEM
2. USED replacement part
3. REBUILT replacement part
4. REMANUFACTURED replacement part.
Consumers should understand these categories, and their differences. While NEW and USED is rather self-explanatory, REBUILT and REMANUFACTURED are subtly different, and carry different warranties, as a rule.
According to the Automotive Parts Rebuilders Association (APRA), the "official" definition of remanufactured is, "Remanufacturing of automotive small parts, such as starters, alternators, clutches, brake calipers and wiper motors, in addition to larger parts, such as engines and transmissions begins with an inoperative, failed or worn out part called a "core". This core is disassembled so that the subsystems and components can be cleaned, tested, repaired/reworked or replaced. The components are then reassembled and tested such that the expected performance of the reassembled equipment can be defined and warranted."
Conversely, rebuilding a part is generally considered to be a simple replacement of only those components that may be broken or unusable, without a complete disassembly and inspection. As an example, a remanufactured alternator will have new diodes, new brushes, an undercutting of the armature coil, new bearings and pulleys. A rebuilt one may only have the brushes replaced.
Because of this small, but important, difference rebuilt parts generally have a much shorter warranty period (30 days to 90 days is normal), while a remanufactured unit will generally have a much longer one, such as 1-year to lifetime.
When it comes to engine replacements, it gets a bit more complicated, since the wording is almost identical. "Caveat Emptor" is the keyword here. Most quality engines will carry an AERA, ARC, or similar decal to identify that the engine has been, literally, rebuilt, using new parts, re-machining of those parts still re-usable, and rigorous testing and inspection standards. Remanufactured, when it comes to engines and engine assemblies, now has turned into a verb, meaning the part was 'Remanufactured in the USA' for example, meaning that it was rebuilt here, using primarily American sourcing for parts.
agency for details -- when replacing an engine assembly, the vehicle will need to be re-titled and registered. This is because the Vehicle Identification Number (VIN) is coded to indicate which engine that PARTICULAR vehicle has, and where it was built. The California Vehicle Code, Section 4161, states:
* (a) Whenever a motor vehicle engine or motor is installed, except temporarily, in a motor vehicle which is identified on the ownership and registration certificates by motor or engine number or by both the motor and frame numbers and subject to registration under this code, the owner of the motor vehicle shall, within 10 days thereafter, give notice to the department upon a form furnished by it containing a description of the motor vehicle engine or motor installed, including any identifying number thereon and the date of the installation. The owner of the motor vehicle shall also submit to the department with the notice the certificate of ownership and registration card covering the motor vehicle in which the motor vehicle engine or motor is installed and evidence of ownership covering the new or used motor vehicle engine or motor installed and such other documents as may be required by the department.
* (b) Upon receipt of motor vehicle engine or motor change notification and other required documents, the department shall assign a distinguishing vehicle identification number to motor vehicles, other than motorcycles or motor-driven cycles registered under a motor number or motor and frame numbers. When the distinguishing vehicle identification number is placed on the vehicle as authorized, the vehicle shall thereafter be identified by the distinguishing identification number assigned.
* (c) Notwithstanding any other provision of this section or any other provision of law, whenever an application is made to the department to register a replacement engine case for any motorcycle, the department shall request the Department of the California Highway Patrol to inspect the motorcycle to determine its proper identity. If the replacement engine case bears the same identifying numbers as the engine case being replaced, the original engine case shall be destroyed. A determination verifying proof of destruction shall be made by the Department of the California Highway Patrol.
Amended Ch. 755, Stats. 1982. Effective January 1, 1983. Amended Sec. 1, Ch. 94, Stats. 2001. Effective January 1, 2002.
The 2001 amendment added the italicized material, and at the point(s) indicated, deleted the following "the department shall not register a case for any motorcycle of the push-rod type with nonjournal rods and four-stroke engines, manufactured in the United States, without proof of the destruction of the case being replaced."
In other words, make sure to re-title a vehicle that has received an new engine. It is important.
Old Jun 29, 2007 | 10:53 AM
NmexMAX's Avatar
dot dot dot ...
I demand cliffs oh mighty sooner.
Old Jun 29, 2007 | 10:55 AM
Kevlo911's Avatar
Kevlo for President
Clearly all this bs does not change anything about the thread....
on selling the car. Only way a VQ35 makes it into my car is if I change the pistons and/or rings to HR stuff. Many replacement motors on my350z still burn oil.
Old Jun 29, 2007 | 10:57 AM
SuperStasiu's Avatar
All i gotta say is VQ30Dek FTMFW WOOT WOOT
Old Jun 29, 2007 | 11:01 AM
NmexMAX's Avatar
dot dot dot ...
I wonder when mine wills tart burning?
Old Jun 29, 2007 | 11:15 AM
RLW001's Avatar
Are they paying or you?
Old Jun 29, 2007 | 11:16 AM
my started in the mid 40s, now i have 59980, but engine is on order so they let me drive the car over 60K with the repair order open
Old Jun 29, 2007 | 11:18 AM
nissan is since i came in at 58400 for the oil burning test, they filled it up, plugged the drain plug and dip stick and told me not to touch it, so i didnt, then came back in at 59920 and it was 2.5 quarts low, my tail pipe has more carbon build up on it them a modded sti lol
i got lucky my car is 03/02 build, so last of 02s and it wasnt sold until aug 5 of 02 so i just made it for the warranty cut off
Old Jun 29, 2007 | 12:26 PM
SoonerFan's Avatar
Cletus
Old Jun 29, 2007 | 12:27 PM
SoonerFan's Avatar
Cletus
which is why im changing rings and pistons when i get home from korea
Old Jun 29, 2007 | 12:28 PM
Kevlo911's Avatar
Kevlo for President
Just don't use Korean pistons/rings
Old Jun 29, 2007 | 01:27 PM
NmexMAX's Avatar
dot dot dot ...
Get them from Human Resources. As well as other items, i.e. Kevlo911's suggestion.
Old Jun 29, 2007 | 01:29 PM
Kevlo911's Avatar
Kevlo for President
Get them from Human Resources. As well as other items, i.e. Kevlo911 suggestion.
High Rev
BTW, looks like im auto for a lil bit longer. Might hit up the track in 100 degree weather and still do good if I feel like it.
Old Jun 29, 2007 | 01:31 PM
NmexMAX's Avatar
dot dot dot ...
How do you feel then?
Little bit longer ? ?
I got a brand new support shift fork assembly FS, PN 34550-40U00 j00 wants?
MAXSE5SPD
Sep 17, 2022 04:00 AM
FlaMark
Jan 8, 2016 07:21 AM
Justin Kroll
Sep 2, 2015 11:06 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 1, 2015 05:27 PM
