Need Help - Front Drivers Side Drain Hole Is Plugged
Old Jun 29, 2007 | 09:15 PM
Dust N Bones's Avatar
Yesterday I washed my car and put it in the garage after drying it. After I put it in I noticed that water was dripping very slowly from drain hole under the car directly behind the front driver side wheel. After about an hour there was a good size puddle right under the hole. So it appears the drain hole is at least partially plugged and I'm wondering if there is anyway I can unclog it.
Old Jun 30, 2007 | 05:04 PM
Maxgig's Avatar
if you have an air compressor you can try blasting the hole with a few shots of air, that worked on my friends Camaro he was restoring a while back.
Old Jul 7, 2007 | 11:18 AM
I tried blasting it from underneath with my compressor and no luck. I don't have a lift so it makes it difficult to get under there but does anyone have any other suggestions? I don't want the car to rot from the inside.
Old Jul 7, 2007 | 01:31 PM
00MaxSE's Avatar
Pointy Elbows
Are you talking about the drain holes in your door?
kingw323
20
Oct 21, 2015 08:36 AM
lowpost99
22
Sep 2, 2015 04:38 PM
KGMtech
Aug 18, 2015 09:21 AM
BassAddictJ
Aug 4, 2015 11:38 AM
