glutch pedal noise
glutch pedal noise
Just curious as to if anyone has experienced this before and how to fix it.
When i depress teh clutch pedal there is a scraping noise, only during the free-play prior to hitting the friction point, and only on the depression stroke, never on rebound. I examined the pedal and linkage, and couldnt determine anything in particular. i have a feeling that the spring just needs lube, but wanted to test the waters. I am wondering if the link shaft requires lube, i am on vacation and dont have my FSM with me. Also, is there a specific way to apply the grease? i am hoping that just slathering some lube on the 3 spring joints will cause it to self feed into the joint.
If anyone knows, please post. If i dont hear back i will let you all know what i find as i test different things one by one.
It should be a non-serviceable part, but if it makes noise, lube it. THats my philosophy at least. Plus if you lube everything you will almost certainly prevent abrasive wear taht will accelerate failure.
06-06-2017 02:01 PM
