replacing rotters
Old Jul 17, 2001 | 05:15 PM
igorsavin's Avatar
I now have 26,000 miles on my baby. I think that I need to go to a dealer to check my rotters and it still should be covered under warantee. However, I replaced my original brake pads after 10,000 miles and have not replace them ever since. I looked last week but there is still plenty of meat left. Should I put the original pads back on before going to the dealer or that shouldn't matter.
Also, when I come there. What exactly should I tell them?
????-->"the rotters are wraped and the tsb requires you to fix them" or something else
igor
Old Jul 17, 2001 | 05:40 PM
Gerry's Avatar
If your pads are not factory type, its unlikely they will do rotors under warranty. I'd put the originals back in if you're expecting them to consider warranty coverage.
Old Jul 17, 2001 | 06:21 PM
s1rch's Avatar
igor
ROTORS? sp
Old Jul 17, 2001 | 06:27 PM
y2kse's Avatar
Originally posted by s1rch
ROTORS? sp
RODERS? sp
Old Jul 17, 2001 | 06:33 PM
VeggieH8R's Avatar
Originally posted by y2kse
RODERS? sp
Does someone make "ricey" rotors for the max? The ones with all the holes and grooves?
Old Jul 17, 2001 | 06:39 PM
y2kse's Avatar
You betcha. Check out www.stillen.com.
Old Jul 17, 2001 | 06:42 PM
UMD_MaxSE's Avatar
Got Bent?
'ricey' rotors?
all those holes and slots do serve a purpose
Old Jul 17, 2001 | 06:46 PM
y2kse's Avatar
Originally posted by UMD_MaxSE
'ricey' rotors?
Right. The holes crack and slots eat up your pads!
j/k
Old Jul 17, 2001 | 06:47 PM
VeggieH8R's Avatar
'ricey' rotors?
I KNOW!!! Just in case no one knew what I was talking about, I described them.
Old Jul 17, 2001 | 06:50 PM
max2kgle526's Avatar
ive had mine replaced 3 times in 24 thousand miles.
Old Jul 17, 2001 | 06:52 PM
UMD_MaxSE's Avatar
Got Bent?
I was just messin wit you man....
it's all good
VeggieH8R's Avatar
That's a rediculous price. Did anyone actually buy them?
Any other companies? C'mon, they're brake rotors. Aren't they standardized or something?
Old Jul 17, 2001 | 07:56 PM
max'n out's Avatar
I have 30,000 miles on my max and havn't changed any part of the factory suspension stuff and it stops same as the day i bought it... Even with the 19"s. I do plan to upgrade to the stillen front kit and prob c/d/s roters lines pads and 2 piston calipers in the back soon though. If you look at all the company's that make brake upgrades there all expensive as hell. Stillen,baer,brembo...all make kits are are all about the same price.
Old Jul 17, 2001 | 10:10 PM
MaineI30's Avatar
rotters??
Are those dead otters?
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
