01 SE Compressor
Old Jul 10, 2007 | 03:10 PM
CraigsMax01's Avatar
01 SE Compressor
looks like my compressor clutch is lockin up, that is the sound i was hearing. 158k miles. anyone else had to replace one?
Old Jul 10, 2007 | 04:09 PM
n e body???
Old Jul 10, 2007 | 04:16 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
You can replace the clutch. I would get a new stator, pulley and clutch set. You will need some snap ring pliers to replace it. There should be enough room for you to do this on the car (won't have to discharge the AC ) if you get some angled snap rings. There is a 10mm bolt in the center you need to remove, this will allow you to remove the clutch. Once you have that off there will be a snap ring that holds the pulley in place. Once the pulley snap ring is off the pulley will come out and you will see the stator- this engages (pulls on the clutch, its an elector magnet )... there is another snap ring inside there that holds the stator to the compressor. Reassembly is reverse way of disassembly.
New clutch should come with selective washers to set the right gap between the clutch and the pulley. I rebuild Honda A/C compressors all the time, big problem on the 05+ RLs. I am not sure if Nissan sells it separate, but the compressors are all very similar. Denso vs Calsonic- very similar in design. Nissan should offer the parts for replacement, especially since the bearing making noise/going bad is very common on the Calsonic variable displacement compressor they use on the 5th gens.
Old Jul 10, 2007 | 04:43 PM
woooooow, damn if this works i owe you big. so anywhere i can find the parts u can think of. i would pay you to get me the correct parts. they quoted me $1000 for the job....
Old Jul 10, 2007 | 10:02 PM
I don't work for Nissan, I work for Acura Ask Dave B on this forum if he can get you the stuff you need. My days with Nissan ended when the 5th gen came out and I got last of the good ones
Old Jul 11, 2007 | 07:31 PM
how do i find him, the find memeber thing is not working?
Old Jul 11, 2007 | 08:47 PM
I don't know.... I used to work for Nissan light years ago, and I go to the dealer I worked at for parts. I still get crazy discounts on all the parts, so I don't shop with anyone else.
On your own pal.
Old Jul 11, 2007 | 08:52 PM
so u cant get it for me? thats cool. i dont have dealership money. thanks for all your help tho
Old Jul 11, 2007 | 08:57 PM
I'm not telling you to pay the 1000 bux they want.... I am telling you to find an online Nissan dealership who will sell you the parts.
I think South Point Nissan in TX is where Dave Burnette works at.
Old Jul 11, 2007 | 09:01 PM
would you go reman? and i will check
05' MaximaMan
Oct 8, 2017 06:36 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
