wiring lights for trailer?
Old 07-22-2007 | 05:29 PM
slydel's Avatar
I put a hitch on, and I can't figure out how to wire in the lights for the trailer.
Suggestions.
Old 07-22-2007 | 05:33 PM
opanick's Avatar
Dont people mess up the frame on their cars when they start towing stuff thats meant for a f-350? lol
Old 07-22-2007 | 06:28 PM
davemac's Avatar
A reciever stlye hitch can be really handy. And when you're not using the hitch which is likely often you don't have to drive a truck.
I've done this on several cars, though not my Max. Anyway it is just a matter of tapping into the wiring at the rear. I assume you have a trailer wire kit that includes a converter. The tail light converter is necessary to combine the turn signal and brake lights which are separate bulbs on your car to a single bulb with two filaments on the trailer. In your trunk I would pull the trim from the back and possibly from the left side (drivers) to get access to the wires to the rear lights. I like to use Scotchlok style connectors (available at Wal Mart or similar ones at any auto parts store) because you don't have to cut and splice wires. If you are not familar with these there is a description and picture here. I looked at the Electrical section of the repair manual and put together the following wire map:
Function -> Trailer plug wire -> Nissan rear light wire (Main Color / Stripe)
RH Turn -> Green -> Green / Yellow
LH Turn -> Yellow -> Green / Black
Brake -> Red -> Red / Black
Lights -> Brown -> Red / White
Ground -> White -> Black
Good luck
SoonerFan's Avatar
Cletus
Suggestions?
dont tow a trailer with a maxima
Old 07-22-2007 | 07:13 PM
slydel's Avatar
Good luck
Thanks you so much for the help.
I will try this soon.
BTW, for all those who don't think a Max can tow a trailer, you're wrong.
There is no reason why this car can't handle a light trailer, I used to tow a caravan, in the UK, with a much smaller vehicle. I have pulled another car with my 95 Max, easily, with the original clutch at 200k miles.
Just learn how to drive.
Old 07-22-2007 | 07:17 PM
Old Blue 66's Avatar
It might be ok to pull a jet ski or somthing like that. But a trailer full of jet ski's? No way
Old 12-08-2008 | 05:10 PM
Nottacop's Avatar
184,000 miles on the car ... 980 lbs trailer ... for 700 miles with a five speed gen. 4 Max. No Problem as the last guy said ... learn to drive. A frame is a frame its not like we are driving aircraft here.
Old 12-08-2008 | 05:31 PM
Drockb418's Avatar
you drive a maxima not a truck,and if you dont have a truck go rent one for a little
Old 12-09-2008 | 07:50 PM
OK.Eric's Avatar
I once saw a 5th gen towing two jet skis, driven by some hot chick.
Old 12-09-2008 | 08:04 PM
JNCoRacer's Avatar
Just the tip.
Ive never had any problems towing with my Max. I pulled my 96 with my 99. Pulled a trailer around for work with a 700lb rooftop AC unit on the back and still pulled on Civics. And just recently pulled a 5x8 tailer with my 97 I30t to move last weekend. No problems at all.
mvm062
11-30-2020 09:00 AM
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
A32goldylocks
09-02-2015 06:39 AM
Viralkill
08-16-2015 05:09 PM
Quick Reply: wiring lights for trailer?
