Bolts for the MAF Sensor
Old Aug 16, 2007 | 07:02 AM
Sunfishsailboat's Avatar
Last night I changed the MAF not a big deal. However, I broke one of the bolts holding it and had to grind it out with a dremel tool, drilled a hole in it and was finally able to get it out using a nail as a handle. Now I know not to over do it, but I wonder if the bolt went bad some how. This bolt is 10mm and is about 1 inch. Anyone else have a similar experience?
Also, these are just 10mm, 1 inch bolts according to Nissan. The local dealer did not have the bolts in stock and said they were common.
Old Aug 16, 2007 | 08:25 AM
Kyle00's Avatar
WSH for teh cup
I'm not sure what to make of this. This is a maxima forum and your asking if there have been problems with bolts?
Old Aug 16, 2007 | 08:38 AM
DasYears
last time i checked there were only torx bolts holding down the MAF sensor
Old Aug 16, 2007 | 10:05 AM
L.M.L.
Are you actually talking about those 4 bolts that hold MAF tube to the airfilter box, right? 6mm bolts with 10mm hex head?
Old Aug 16, 2007 | 11:55 AM
jkayca's Avatar
I can't believe your local dealer doesn't have any bolts. Just about everything in Maxima's the engine bay is held down by the same 10mm bolt. Go to your local hardware store or Autozone. They should have replacement bolts.
Old Aug 16, 2007 | 12:39 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
You mean I have to worry about my bolts going bad too?
Old Aug 16, 2007 | 12:56 PM
Bufflomike's Avatar
Sexier Than Simpson
I know in Buffalo I do because of the damn rust...dont these MAF's have enough issues without bolt deterioration
Old Aug 16, 2007 | 01:34 PM
DasYears
i actually had a bolt crumble in my hand the other day, then the wind blew and i had no proof of said crumbling
Old Aug 16, 2007 | 01:35 PM
Trurida18's Avatar
just go get some bolts from ebay, or your autoparts store.....u can reuse the washers
Old Aug 16, 2007 | 02:38 PM
burnurass's Avatar
home depot run, maybe?
Old Aug 16, 2007 | 03:55 PM
Yes- These are the ones there are (4) 10mm bolts
Old Aug 16, 2007 | 03:57 PM
I bought the home depot ones since the dealer said they did not have them.
Old Aug 16, 2007 | 03:58 PM
After the dealer said they did not have them, he said Home Depot and off I went. I didn't even tighten these up that much which is what surprised me.
Old Aug 16, 2007 | 04:00 PM
Here's the thing. Mine were not rusty! I know that I did not tighten them up that much either. So, I got a couple at Home depot and swapped it with another one that was easily accessible. I think the bolts in the engine are a grade 8 type. This was very unusual for me when it happened.
Old Aug 16, 2007 | 05:15 PM
MacGarnicle's Avatar
why were you removing the entire assembly?
Old Aug 17, 2007 | 06:28 AM
jkayca's Avatar
He's probably a MAF virgin
I did the same thing since I didn't have a torx bit.
Old Aug 17, 2007 | 08:57 PM
No I had the torx bit and even cleaned the sensor as well with MAF cleaner. I removed it and followed what I received in the box, even though most people said you did not have to change it.
-ReLLiK-
Apr 29, 2016 06:25 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
jcvgn
Sep 13, 2015 11:42 AM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
