Programing Keyfob
Old Aug 20, 2007 | 10:36 AM
Prophecy99's Avatar
Programing Keyfob
My question is can anyone verify if this procedure works for 5.5 gens?
Originally Posted by Clipper821
6th gen Remote programming instructions:
1. Get in & lock the doors.
2. Insert the key into the ignition 6 times within 15 seconds.
3. Hazzard lights should flash.
4. Put key back into the ignition & turn to the run position but do not start.
5. Hit the lock button on the remote.
6. Hazzards should flash.
~If additional remotes go to step #7~
~No additional remotes go to step #8~
7. Unlock and lock the doors with the lock switch on the door and go to step #5.
8. Pull key out and open the drivers door and then close it
9. It should be set.
Remember if you have more than one remote you must program them all at the same time
searched and this is all I came across, but no one had verfied if it worked for us in that thread. TIA
Old Aug 20, 2007 | 10:41 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
I got in, locked the doors. Turn the key to run and pushed the lock button. Viola!!! For me anyway.
Old Aug 20, 2007 | 10:44 AM
Puppetmaster's Avatar
http://forums.maxima.org/showthread....program+remote
Old Aug 20, 2007 | 03:37 PM
Prophecy99's Avatar
allways something
Originally Posted by Puppetmaster
thanks pm, I followed that... and still get nothing
purchased brand new battery installed it properly
I initialize the programming correctly as it flashes hazards, I put it on ACC and hit my button and nothing...
Tried 5 times.. and everytime the button dosent flash Hazards.
Any ideas
Old Aug 20, 2007 | 04:14 PM
TurtleHead
Is this a new OEM keyfob? If not, maybe your original keyfob is broke?
Old Aug 20, 2007 | 04:27 PM
xnyc's Avatar
Any ideas
car needs to go to ON position not ACC.
Old Aug 20, 2007 | 05:19 PM
Prophecy99's Avatar
tried that still nothing
Old Aug 20, 2007 | 06:20 PM
Dust N Bones's Avatar
Are you sure the key fob works? It really sounds like there is something wrong with the key fob.
Old Aug 20, 2007 | 06:50 PM
nsnrider's Avatar
try it again, i had to try 10 times on one of my cars to get it working, go slower too.
Old Aug 20, 2007 | 08:01 PM
TheBigDu's Avatar
I am ashamed to admit this because I like to think I'm reasonably mechanically inclined and not stupid...but here goes...
I had this problem a few years ago with mine...wasn't a new fob, just a new battery in the old one...I tried this procedure many times...I got the car the respond every time, but the fob just wouldn't work...
As a last resort I thought to myself that MAYBE I'd put the battery in backwards...and then I felt stupid when I found that I had...
Let's just say make sure your battery is in correctly...and if it was in backwards, you'll probably need to replace it again because it drained while in backwards...
Old Aug 22, 2007 | 05:47 AM
Prophecy99's Avatar
this....keyfob... is still not giving any feedback.
new battery. new keyfob?
I can intialize the program correctly and when its time to hit a button I get nothing? Any ideas anyone? (How can I find my FCC/serial # if i never had the orginal kf )
Old Aug 22, 2007 | 05:35 PM
Can you post a picture of the key fob you have?
Old Aug 22, 2007 | 09:32 PM
02Maximan's Avatar
I think on the remote that I bought off ebay it came with those instructions. It didn't work for me either, so i went to programyourremote.com and there is a little variation in the procedure and it worked for me. Don't know if you have tried that or not, but I had the same problem. I thought I had bought a bad remote until I tried the online instructions.
Old Aug 23, 2007 | 09:14 AM
Froggmann's Avatar
In case of future searches:
Program your Remote 5.5 Gen (2002-2003)
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. ( Withdraw key completely from ignition cylinder each time ) . If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the keyless remote. Your Hazard Lamps should flash. ( Do not press the button more than one time in the above step). If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each keyless remote (including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Old Oct 12, 2007 | 02:56 PM
Orgullo's Avatar
Sorry to bump this thread but...
Does anyone know how to make the horn sound again with the lock button on the key fob? I am able to lock/unlock the doors but the horn doesn't sound. Thanks.
Old Oct 12, 2007 | 04:05 PM
Peanuthead's Avatar
Hold down the lock and unlock together until the lights flash. Done.
Old Oct 12, 2007 | 04:12 PM
Orgullo's Avatar
Awesome man... thanks... worked like a charm
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
