fuse keeps blowing
Old Aug 27, 2007 | 07:46 AM
klee215's Avatar
fuse keeps blowing
Hey quick question,
I tried to plug in something in my outlet and it keeps blowing the fuse.. even if i just stick the adapter in by itself , it still blows the fuse out.. any idea what could be causing the blow out. i tried diferent adapters and the same result..
Old Aug 27, 2007 | 08:33 AM
Professor's Avatar
Replace outlet.
Old Aug 27, 2007 | 09:44 AM
nsnrider's Avatar
Originally Posted by Professor`
Replace outlet.
I agree with Professor'
+1
Old Aug 27, 2007 | 11:53 AM
freshv6power's Avatar
Check to make sure there's nothing in the outlet. That happened in my old car. There was a led in it.
Old Aug 27, 2007 | 12:45 PM
MaxBoost925's Avatar
Drug Money
You might have a short somewhere.
Old Aug 27, 2007 | 03:30 PM
Torgus's Avatar
replace the fuse with a paper clip?
Old Aug 27, 2007 | 06:19 PM
Zero Deuce SE's Avatar
No, that will likely burn his car up in short order.
Old Aug 27, 2007 | 06:34 PM
Torgus's Avatar
are you sure?
Old Aug 27, 2007 | 07:39 PM
Drockb418's Avatar
you gotta do wat u gotta do getto rig it ~!!!
Old Aug 27, 2007 | 07:55 PM
Professor's Avatar
lol O_o, btw nice car, its my cars twin.
Old Sep 3, 2007 | 08:14 PM
pikers's Avatar
Originally Posted by klee215
Hey quick question,
What else do you have tied into this? Anything t-tapped into the power lead?
Check to see if there's a snip or break in the insulation on the wire (power or ground) touching metal behind the dash. Should be easy enough.
Old Sep 3, 2007 | 08:31 PM
Drockb418's Avatar
thanx man
Old Sep 18, 2007 | 01:57 PM
bluefire's Avatar
dont ever put a paper clip in for a fuse
i would replace the outlet and check the wiring to make sure there is no breaks in insulation that will catch a ground.all of which some one has said above, but a couple more opinions help.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
