Help/Suggestion For Removing O2 Sensor
Old Sep 3, 2007 | 07:44 AM
PadawanKnight's Avatar
Before I pose the actual question, I want to qualify it with this disclaimer:
I had back surgery in Dec and unfortunately my strength isn't near what it used to be.
Okay, so here's the deal. I bought an O2 sensor from DaveB and tried to install it yesterday (downstream, btw). The problem was, I just wasn't able to get the old one to budge.
I tried warming up the exhaust for a few minutes.
I tried PB Blaster.
I tried both.
Nothing.
Any ideas what else I could do? Thanks for your help.
Old Sep 3, 2007 | 07:47 AM
TurtleHead
Soak it with the PB blaster a few times and let it sit for a couple hours. If that does not help, you will probably need a torch to heat it up enough to remove.
RLW001's Avatar
I let the PB blaster soak in for awhile, then tapped on my wrench in both directions and it broke free. It doesn't help that there is little room to work.
Old Sep 3, 2007 | 08:11 AM
nlmaxima's Avatar
I would heat it up cherry red and cool it with water. If that doesnt work heat it cherry red and remove it while hot but be prepared for the threads on the pipe to be ruined. You can get a spark plug thread chased for fairly cheap at an auto parts store so I suggest having it when you remove it just in case. If you don't use it then return it. Get someone to help you if your back is bad or if you may risk hurting yourself again.
Old Sep 3, 2007 | 08:43 AM
Thanks for the suggestions. I'm having lunch with a friend today that's been pretty good about helping me with issues on my other cars. Maybe he'd like to help me with this one. Maybe all the PB Blaster I sprayed on yesterday will help out today.
Old Sep 3, 2007 | 01:36 PM
wyche89's Avatar
all of that stuff, plus try a bigger wrench.. or u can hook one wrench onto the back of the one you're using for more torque.. worked for my 02 sensor
Old Sep 3, 2007 | 02:37 PM
ODB's Avatar
ODB
Yeah, I had to bang the wrench pretty hard with a hammer. Just when I was about to give up, bingo
Old Sep 3, 2007 | 04:52 PM
Thanks for the help guys. My friend was able to finally get enough torque on the sensor and get it loose. Obviously, the replacement was MUCH easier to get in.
Now comes the real test: Was that the only issue for the SES light?
Old Sep 3, 2007 | 07:16 PM
rmh3093's Avatar
Only gentoo powered Maxima!
sea foam did the trick for me.... definately had to let it soak in for a while though
Old Sep 18, 2007 | 01:59 PM
bluefire's Avatar
they make a niffty tool to help get a good grip and leverage on the sensors, you can find it at auto parts stores around town
Old Sep 19, 2007 | 01:09 AM
MaxBoost925's Avatar
Drug Money
Nah. 22mm crescent wrench works better.
Old Sep 19, 2007 | 07:39 PM
justinny's Avatar
dont forget to use a little anti seize lubricant on the threads b4 u install it just in case you have to change it again at some point
bbsitum
Sep 6, 2019 07:31 PM
bumpypickle
Sep 20, 2015 08:22 AM
ac max 92
Sep 17, 2015 07:35 AM
