View Poll Results: GC Coilovers or Eibach Pro-kit?
GC Coilovers
50.00%
Eibach Pro-kit
50.00%
Voters: 18. You may not vote on this poll
Help me decide: Eibach Pro-kit or GC's
Old 08-02-2001 | 09:06 AM
  #41
Y2KevSE's Avatar
Rice Boy in Denial =)
Originally posted by Dustyroads
You don't need to compress the GC's when you put them in?? Ok, but don't you need to compress the stock spring in order to remove it? Damn, I'm asking a lot of questions....sorry about monopolizing your time Kev. One more, how much of the bump stop did you cut off and where the heck is it??
Nope... no need to compress the GC's. You don't need to compress the stock spring before taking it off (you should, but it's not necessary).
You're not monopolizing my time. It's either me helping you or me spa..... participating.
For the bumpstops, I suggest using only the top stump. Basically, cut off the top ring and use that.
Old 08-02-2001 | 11:45 AM
  #42
Dustyroads's Avatar
Ok...so use the normal 4th gen procedures for the strut housing modification, you don't actually have to compress the spring, hmmm...that's interesting. Then for the bumpstops cut off the top ring and use that. Did I miss anything?? Oh yeah, what about the rears? Anything special that you have to do back there? Is it just remove and replace? Just making sure again. Again Kev, thanks for the info. I want to be prepared when I get these bad boys. Oh yeah, where did you put your spring settings to initially? Did you adjust them to the highest height and then adjust from there? Okay...more later I'm sure!!
Old 08-02-2001 | 01:37 PM
  #43
Y2KevSE's Avatar
You're welcome.
Same thing for the rear. Just use the top because it supports the other part of the mount.
Set the springs to the highest setting?!?!? Nah... we set it at the lowest and went upwards. I have 6" springs, so we started out by turning the perch 10 times (full revolution).
imported_Nismo_max
02-17-2016 03:39 AM
Peter Paul
01-02-2016 05:18 PM
morteljc
10-19-2015 10:47 AM
95Maxi
35
09-02-2015 10:37 AM
official_style
08-29-2015 10:10 AM
Quick Reply: Help me decide: Eibach Pro-kit or GC's
