4gen FSTB on 5gen? possible?
Old Aug 7, 2001 | 06:17 PM
LoveSick's Avatar
I am really wondering if the 4gen FSTB will work on 5gen Maxima!?
If you know, please tell me. I am planning to get one from Greg.....
Old Aug 7, 2001 | 06:18 PM
UMD_MaxSE's Avatar
Got Bent?
you will have to cut off a small part of a metal bracket that is on the driver side strut tower...
Old Aug 7, 2001 | 06:20 PM
LoveSick's Avatar
cutting the suspension components?
Old Aug 7, 2001 | 06:26 PM
UMD_MaxSE's Avatar
Got Bent?
no, it's just a part of a metal bracket that holds the air box
Old Aug 7, 2001 | 06:28 PM
LoveSick's Avatar
any pix?
comon, gotta help out a poor guy with only 45bucks to spend!!!
Old Aug 7, 2001 | 06:36 PM
UMD_MaxSE's Avatar
Got Bent?
check it out:
http://www.chrislehr.com/maxima/fstb.html
scroll down to the end for the pic you are looking for...
LoveSick's Avatar
thanks!
Old Aug 7, 2001 | 06:40 PM
UMD_MaxSE's Avatar
Got Bent?
what do you need to cut it with?
hacksaw...
Old Aug 7, 2001 | 06:44 PM
almason's Avatar
Sort of. You saw the reply noting that you have to cut into the air box bracket, but there is another problem. The 4th Gen bar does not raise high enough over the wiring harness at the back of the engine. You actually have to push the bar down on the wire harness during the install. This is not good -- the engine moves around a little during driving while the strut bar does not. I would expect some insulation to eventually be cut or worn off to cause a variety of problems. I would stick with a bar that fits.
Old Aug 7, 2001 | 07:08 PM
irvine78's Avatar
o~k...the 4th gen front strut tower bar will NOT work on a 5th gen. reason? because, the 5gen engine has higher intake manifold which prevent you from using a straight FSTB...if you look at a 5th gen FSTB and a 4th gen FSTB, you'll notice that it's different..
Old Aug 7, 2001 | 10:11 PM
WILLSE's Avatar
thanks u beat me to it.... as a matter of fact stillen sent me the strut tower brace for the 4th gen and me not knowin any different out it on and took it for a spin but heard wierd knocking.... i get home check it out and realize that the engine flex was causing the engine to hit the strut tower brace and boy was i ****ed! i thought that it looked close but i had no clue.... so the answer is NO.... it has been tried but not on purpose dont do it u r wasting ur money!
Old Aug 7, 2001 | 11:05 PM
ohboiya's Avatar
why don't u get 1 that was specifically made 4 your car? u paid ... prob about $36-39K CDN 4 your car right? what the hell is $180 USD going 2 b in the long run?
then again .. that logic has cost me close to $3200 CDN since I bought this beast! so it mite not b a bad idea 2 ignore that ...
n e ways ... they do have 'em cheaper ... check out eBay ... perfect fit 5th gen fstb 4 a lot less .. even courtesy has one for $89 ... but I think eBay mite b cheaper ... not 100% sure ...
Ben2003GLE
31
Jul 17, 2016 08:13 AM
2000MaximaSE
Dec 12, 2000 10:35 PM
Nismo87SE
Nov 1, 2000 06:11 PM
josh95se
Oct 16, 2000 06:34 AM
