2K2 HID Headlamp Assembly arrived TODAY!!!
Old Aug 23, 2001 | 09:18 PM
BigDogJonx's Avatar
Got them from DaveB today and let me tell you, the install it going to take me 15mins a side.
There are a total of 7 wires you need to hook up.
3 for the Xenon plug, (1ground, 1positive for HID, and 1positive for clear parking corner light)
2 for the turn signal (1ground, 1positive)
2 for 9005 High beam bulb (1ground, 1positive)
I can see this install taking no more than 5mins on the wiring. Just a matter of splicing into the wires.
For all of you who thought the clear corner was a light that comes ON with the turnsignal is WRONG. It is simple a wedge bulb that comes on with your parking lights.
This is the THE most simplest wiring assembly on the planet. DaveB hooked me up in the sense where he found all the adapter plugs so I makes my life ALOT easier.
You can see the pics I just took for a better picture of what I am talking about.
http://www.geocities.com/dsuthar/hids/
And dont harass me about installing them right now, I am in the process of moving and my fiance already *****ed me out for opening the box and taking pictures while she is packing.
Dixit
Old Aug 23, 2001 | 09:32 PM
big h's Avatar
DUDE...WHERE ARE YOUR PRIORITIES? j/k!!! We'll give ya til tomorrow to post something or ELSE!!!!
Old Aug 23, 2001 | 09:53 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Dixit
I feel you on that one.
Old Aug 23, 2001 | 10:10 PM
2000MaximaSE's Avatar
Sounds simple as hell. With more lights in front that means more lights to rewire to blink!! Im gonna wire up the parking light to blink with the side marker, which will be alternate blinking from the blinker.... Sweet
Adam
Old Aug 23, 2001 | 10:20 PM
ohboiya's Avatar
Adam
yo .. you're going 2 need 2 post some pretty explicit how-to's 4 the DIYers that have green thumbs!
Old Aug 23, 2001 | 10:54 PM
DooBall's Avatar
hurry up and get some pics up of the 2000-1 max w/ the 2k2 hids!
Old Aug 23, 2001 | 11:23 PM
ReprEsenTin NY's Avatar
Hey, how much did the HID's for the 2002 cost?
Old Aug 23, 2001 | 11:25 PM
BigDogJonx's Avatar
Cost me $440 shipped. Includes the HID bulbs Balast, Headlight assembly and wiring harnesses. This is for both sides.
Dixit
Old Aug 23, 2001 | 11:41 PM
ohboiya's Avatar
Hey there,
Where'd u get your superwhite led hood lights? & how much were they? loox good!
Dixit
Old Aug 24, 2001 | 04:42 AM
UMD_MaxSE's Avatar
Got Bent?
cool stuff man!
Old Aug 24, 2001 | 05:08 AM
psing23's Avatar
Dixit
wasnt it supposed to be like $180 a side?
Old Aug 24, 2001 | 05:11 AM
UMD_MaxSE's Avatar
Got Bent?
the wiring harnesses brought the price to a little more...
Old Aug 24, 2001 | 05:13 AM
psing23's Avatar
o the harness is already made? thats cool... so no need to cut the stock wires? its just plug and play now or still gotta do cutting?
Old Aug 24, 2001 | 05:17 AM
UMD_MaxSE's Avatar
Got Bent?
Well, you still need to splice the stock power and ground wires to get them hooked to the assembly. This assembly has more bulbs than the stock assembly
Old Aug 24, 2001 | 05:38 AM
mbcp_tdogg's Avatar
Looking forward to the sticky.
Old Aug 24, 2001 | 06:34 AM
Max_Gator's Avatar
What are the Fogs like on the 2k2?
Seems like with the HIDs, the fogs become pretty useless. Does anyone know what kind of bulbs they are using on the 2k2 for the fogs?
I'm definitely in for the HIDs once someone does a comprehensive how-to.
Old Aug 24, 2001 | 07:39 AM
sixman
Quick question. SInce the 2k Max has a light switch that does not allow low beam and high beam to be on at the same time, how do you plan to get around this? Additional relay, rewire of current relays?
Good luck with you move.
Old Aug 24, 2001 | 08:04 AM
Max_Gator's Avatar
Are the HIDs any different? Most don't even have high beam but I understand that these do. I would assume there is a high beam and low beam HID - hence the two large "eyes."
Old Aug 24, 2001 | 08:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Dixit
There called running lamps, hence they come on when you turn the combination switch not just with turn signals.
5-mins. ya right. Don't forget about the two relays and fuse block you'll need along with making every connection moisture proof or else down the road you'll regret it. Also, the stock harness will not support 35Watts + 60Watts, so don't even think about using it for both grounds. Anways, good luck and I look forward to hearing IF the HIDs work with just power/ground.
Old Aug 24, 2001 | 08:27 AM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by IceY2K1
Old Aug 24, 2001 | 08:28 AM
IceY2K1's Avatar
Damn you! You're too quick.
Old Aug 24, 2001 | 09:57 AM
UMD_MaxSE's Avatar
Got Bent?
sorry
TallTom
57
Oct 14, 2025 05:16 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
