_-=****Throttle Body Not Fully Opened at WOT?****=_
Old Aug 26, 2001 | 07:14 PM
DeaZaL's Avatar
I heard that this could be adjusted.. If so HOW? and.. if I did.. would I need to reprogram the ecu?? I heard someone from avalon racing talking about this one time..
Old Aug 26, 2001 | 10:08 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
No ECU reprogramming will be necessary, but the Throttle Position Sensor might need adjustment. Tell me how if you figure it out. I plan on checking next time I remove the intake track.
Old Aug 27, 2001 | 03:50 AM
DeaZaL's Avatar
k
will do borthaaa
Old Aug 27, 2001 | 05:09 AM
UMD_MaxSE's Avatar
Got Bent?
I remember that post.... Paul from Avalon said something like the TB only opens up 90% or 95% of the way at WOT and they have a way of opening it fully...
Old Aug 27, 2001 | 07:22 AM
IceY2K1's Avatar
I've seen this before on motorcycle engines..
You adjust the stop screw or whatever it is that prevents the "butter-fly" from opening too far. I haven't been that close to see what's up with ours.
Old Aug 27, 2001 | 02:56 PM
got rice?'s Avatar
if the TPS measures 4.0, it's at WOT. The throttle plate itself will not be completely horizontal.
Old Aug 27, 2001 | 03:49 PM
DeaZaL's Avatar
explain rice boy
Old Aug 27, 2001 | 04:06 PM
UMD_MaxSE's Avatar
Got Bent?
Re: ?
explain rice boy
I think 4 is referring to the voltage drop across the TPS and ground.... right? I'll try and look it up...
Old Aug 28, 2001 | 04:11 AM
Avalon Racing's Avatar
Re: Re: ?
E-mail my race tech @ Jeff@avalonracing.net. He can give you thge details. We have made the throttle body adjustments on Z's on the dyno and have achieved just under 10 RWHP. They key is to get the plate to open at 100%
Regards
Old Aug 28, 2001 | 09:19 AM
Max_Vader_2K's Avatar
anyone figure out how to do this yet?
I am very very interested in this!!!
Old Aug 28, 2001 | 09:38 AM
got rice?'s Avatar
Re: ?
explain rice boy
at idle the TPS voltage is around .45 volts. at WOT, it's around 4.0 volts. If you adjust the throttle plate to be more horizontal at WOT, it won't be at the proper position when you're off the throttle. The throttle plate will be more towards the open position if this adjustment is made.
Old Aug 28, 2001 | 06:43 PM
nvmymax2's Avatar
TPS adjusted...
I had to adjust the TPS on my max because the ZEX kit calls for 4.0 Volts at WOT and the max only gives you 3.8 or 3.9. I don't know the truth behind whether or not this allows the throttle to actually open more, but it does allow the ZEX to work properly.
Old Aug 29, 2001 | 04:42 PM
DeaZaL's Avatar
Have you done it to any 5th gen's avalon guy?
Old Aug 30, 2001 | 04:04 AM
Re: ??
Every Limited Edition we do for Nissan has the adjustment done. Also every Maxima that comes in for an upgrade to do.
Regards
Old Aug 30, 2001 | 01:10 PM
how in the world....
do you adjust the throttle thing to open all the way at WOT
Old Aug 30, 2001 | 01:31 PM
UMD_MaxSE's Avatar
Got Bent?
Re: how in the world....
but it sounds like sticky thread material
Old Aug 30, 2001 | 10:30 PM
nvmymax2's Avatar
TPS>
The way I did mine was to look on the firewall side of the throttle body and you will see a large sensor that is actually 2 sensors. First you have to find the "hot" wire in these sensors with a volt meter. It will be the one with 3.9ish Volts at full throttle, and about .4 or .5 at idle. Then you look on the sides of this sensor and you should see 2 screws. Very slowly loosen these screws, it doesn't take much force or rotation of the screws to make the TPS loose! Once this is done you can rotate the whole sensor clockwise and counterclockwise. Well all you do now is rotate it while looking at the volt meter and when you see the volt meter move from .5 at idle to about .7 or .8, you are done. This has successfully adjusted the TPS to be wide open and to test your work, check the voltage at full throttle and it should be around 4 or 4.2 volts. Once you are certain that you are finished just tighten the 2 screws back and go test drive. I am not sure how much of a difference you will notice, because when I did mine I was more interested in playing with the nitrous than I was worrying about this extra little power. Good luck and be careful.
Also I just wanted to let you know that if your local dealership finds out it will probably void some warranty.
Old Aug 31, 2001 | 12:57 AM
Re: TPS>
How do you like the Zex kit anyway, I almost order it but I heard it sucked but if you say other wise I will still get it. and how was the install.
Old Aug 31, 2001 | 01:29 AM
melanthius's Avatar
Could someone explain this to uneducated folk like me? Much appreciated.
Old Aug 31, 2001 | 08:22 AM
How to
We are going to do a technical write up and do a few digital shots on this process. Jeff our race tech and fabricator is working on it now.
Regards
Old Aug 31, 2001 | 08:26 AM
UMD_MaxSE's Avatar
Got Bent?
Re: How to
Regards
thanks.... sounds like a neat thing to try out
Old Oct 22, 2001 | 09:25 PM
theMax's Avatar
how to do this?
Is the write up from avalon complete?
Old Oct 23, 2001 | 12:31 AM
IceY2K1's Avatar
The TPS adjustment does nothing performance wise...
It's the Throttle Plate/Butterfly that needs to be "opened up". However, the TPS will most likely need to be adjusted once you mess with the throttle plate.
Someone needs to call Paul or email his tech for some details/pics.
Old Oct 23, 2001 | 04:56 AM
UMD_MaxSE's Avatar
Got Bent?
wow... who brought this thread up again?
Old Oct 23, 2001 | 06:34 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Oct 23, 2001 | 07:39 AM
theMax's Avatar
me
Originally posted by Y2KevSE
Old Oct 23, 2001 | 07:43 AM
Y2KevSE's Avatar
Re: me
Originally posted by theMax
j/k Hehehehe
Guess we never heard back from him.
Old Oct 23, 2001 | 12:34 PM
psing23's Avatar
seems interesting... any new info yet?
Old Oct 24, 2001 | 06:39 AM
SC2K1's Avatar
Avalon Racing,
Will you be posting the write up on your webpage or on this forum? Please let us know. Thanks.
Old Oct 24, 2001 | 07:40 AM
WANNARUN's Avatar
Some of you guys are a little confused
Adjusting the TPS sensor alone will NOT give you any performance gains.
Adjusting the butterfly in the throttle body (so that it is straight with the airflow path) will give you performance gains.
Once you adjust the butterfly you will need to readjust the TPS.
I adjusted the Butterfly on my 01 AE only a little as it almost opened all the way from the factory.
I adjusted a friends Butterfly a whole helluva lot and he noticed a considerable gain (his was adjusted very poorly from the factory)
Also high mileage vehicles will see higher gains because over time the throttle cable stretches making the butterfly not open enough.
Old Oct 24, 2001 | 07:55 AM
SC2K1's Avatar
WANNARUN, Thanks for the clarification. Can you let me know how both of these are done? Thanks.
Old Oct 27, 2001 | 07:40 PM
OK NOW...........
How do you adjust the throttle butterfly?????
Old Oct 28, 2001 | 05:48 AM
UMD_MaxSE's Avatar
Got Bent?
Re: OK NOW...........
It's probably in the Factory Service Manual somewhere..... I can check
Old Oct 28, 2001 | 06:14 AM
DeaZaL's Avatar
Where is the write up from the tech with nice pictures?!?!?
Old Oct 28, 2001 | 07:50 PM
theMax's Avatar
Re: ??
still waiting....
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
