Hmmmmmmmmmmmmmmmm........................... (supercharger related)
Old Sep 2, 2001 | 10:09 PM
  #41
Y2KevSE's Avatar
Rice Boy in Denial =)
Originally posted by MaXAnDy
good luck dont blow urself up.
Hehehe.... thanks.
  #42
Y2KevSE's Avatar
Re: Re: ....
Originally posted by matt calder
Well i will be waiting for you with open arms
hehehehehehe
you need to slow down a little cause i am trying to catch up with you and you are making it kinda hard to. stop punk
Hurry up slowpoke. :P
Old Sep 2, 2001 | 10:11 PM
  #43
Y2KevSE's Avatar
Re: Re: Re: Re: ..
Originally posted by yo_its_ok
23mpg before ?
I'm logging 26mpg+ before the blower, and still working out bugs in the S/C. Trying to get prices from a manufacturer to make the mounting brackets, and idler pulley.
Holding off on my NX Kit, just too much at once I think...I know someone will read it and say, never enough...LoL
I think everyone hates Jeff @ STILLEN.
-Peace
Stick the NX kit on because nitrous helps cool down the charged air.
Wwwwwwwwwwweeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!! !
Old Sep 2, 2001 | 10:19 PM
  #44
max'n out's Avatar
i'm getting about 19-20 mpg.
Old Sep 2, 2001 | 10:29 PM
  #45
Y2KevSE's Avatar
Is that after the SC?
Old Sep 2, 2001 | 10:50 PM
  #46
max'n out's Avatar
yeah... i got about 22 mpg before...it all depends how hard i drive
Old Sep 2, 2001 | 10:53 PM
  #47
Y2KevSE's Avatar
Definitely tell us what you're getting after the install. I think DMan gets a lot per gallon.
Old Sep 2, 2001 | 10:57 PM
  #48
max'n out's Avatar
Re: .
It's in now and i get about 19-20 mpg where as before I got about 22mpg.
Old Sep 2, 2001 | 10:59 PM
  #49
Y2KevSE's Avatar
Re: Re: .
Oooooooo....... OK, I was confused because you didn't state NA or FF. All clear now.
Old Sep 3, 2001 | 10:27 AM
  #50
melanthius's Avatar
You guys should come to Los Angeles, you'd not get nearly as good mileage! Damn it, I hate refueling after driving only 220 miles.
Old Sep 3, 2001 | 10:57 AM
  #51
DMan_2KMax's Avatar
Re: .
I average 22 to 23 mpg with the supercharger and sometimes 21 mpg when I really hotdog it a lot.
Old Sep 3, 2001 | 11:14 AM
  #52
DMan_2KMax's Avatar
Hey Kevin . . .
The boost gauge was moved to another vacuum line yesterday. During the only test run, I saw the needle up around the 8.5-9 area before taking my eyes off the gauge. Hint: The New CLIMAX (maybe you can finally get above 2 )
I have a feeling I'll be looking for a new tranny once this gets put on. The car should be running around 11 psi or so. Wwwwwwweeeeeeeeeeeeee!!!!!!!!!!
Yes..... I'm nuts.
Are you looking to sell your 3.25" pulley and if so how much? I might just be interested. Did the FMU require a different disk and what size belt would I have to get? Also what kind of boost were you seeing with the pulley? (Isn't it suppose to be around 9-10 lbs of boost?) My stock 3.6" pulley is making 6-7 lbs of boost (just above 0.4 kg/cm2 to 0.5 kg/cm2) on my Greddy boost gauge. With all my tranny mods how do you think the 3.25" pulley would do on my car?
Old Sep 3, 2001 | 11:19 AM
  #53
DMan_2KMax's Avatar
Aftercooler
That's why I have the intercooler, and water injection.
Give me your impression of the ERL water injection system and if you felt it was worth the price. What kind of performance gains did you see?
Old Sep 3, 2001 | 09:43 PM
  #54
Y2KevSE's Avatar
Re: Hey Kevin . . .
I gave the smaller pulley to Chebosto (he's on vacation in NorCal). Yes, the FMU can be purchased from http://www.vortechsuperchargers.com The belt size should be K060705 (Gates part number).
Yup, the 3.25" is suppose to give about 10 PSI. I used to get 6, but since the boost gauge is using another vacuum line I'm getting much higher readings.
With all the mods, I still don't think it's safe for our trannys. I wouldn't recommend it if you worry about blowing stuff up.
Old Sep 4, 2001 | 02:41 PM
  #55
DMan_2KMax's Avatar
Re: Re: Hey Kevin . . .
How do you feel about the 3.33" pulley for my setup? Do you think that would be relatively safe.?
Old Sep 4, 2001 | 09:46 PM
  #56
Neo Max's Avatar
Two questions. How much boost can we run on a 5-spd before clutch replacement is mandatory? You guys have me drooling over the idea of 350hp but this is going to turn into a $5000 deal or more if I need to replace the clutch. (I know 11psi will liquidate a stock cluth but what about 7-8psi?) Also, I was going to sell my car because I was ****ed-off about not having an lsd until I laid down TWIN 90 foot patches. How can that be if I don't have a limited slip?
Old Sep 5, 2001 | 06:53 AM
  #57
Y2KevSE's Avatar
Re: Re: Re: Hey Kevin . . .
3.33" is relatively safe. That would be a good conservative-sized pulley to run. I believe you might be able to put down about 270-280 with that pulley due to your high dyno number off the stock pulley (not including y pipe).
Old Sep 5, 2001 | 07:00 AM
  #58
Y2KevSE's Avatar
I believe 7-8 psi will work on your car with no problems (at least from the beginning). The stock clutch will probably wear out faster. 7-8 should be the 3.48" pulley.
Old Sep 5, 2001 | 07:22 AM
  #59
Y2KevSE's Avatar
I wanna see Kev lay down 90ft twin patches of rubber.
As for LSD Q....sometimes you break both tires loose, but majority of the time its one. I've one a burnout with both tires peeling, then it stopped, and I put on a smoke show for all the civics in the lot on DPA. Best one was breaking the tires loose, and having smoke come in and i'm swatting the smoke, and turning the wheel, so it looked like a restrained pit bull swerving trying to break his chain loose, and with the HIDs piercing through the smoke, it was a picture perfect opp, but no camera
-Peace
No burnouts from me... don't want a blown up tranny. Hehehehe
You should've brought a camera.
Old Sep 5, 2001 | 08:02 AM
  #60
Y2KevSE's Avatar
Re: Re: .
Had plenty of people there, MPNY, 1HOTMAX, RBa, Clee.
I think Clee had a camera, but didn't really know him back in winter time.
Maxima97GLE put on a show of reverse donuts, and a burnout as he swung out of it.
All of you are tire killers!!! Imagine burning out with SO2's.
Old Sep 5, 2001 | 09:38 AM
  #61
matt calder's Avatar
Re: Re: Re: .
All of you are tire killers!!! Imagine burning out with SO2's. eek:
or with t1-s's, no more burnouts for me, got good tires on now.
Old Sep 5, 2001 | 10:26 AM
  #62
Y2KevSE's Avatar
Hogan - CEO, Tire Killer's Club and a member of Boost ****** Anonymous
Old Sep 5, 2001 | 11:33 AM
  #63
Y2KevSE's Avatar
You have the SC on the car already? Did you put the MAF before or after the BOV? Taken itout for a drive yet? I get hesitation at about 3K or 90 mph (won't happen if I give it more gas).
We both have broken ka's...
Old Sep 5, 2001 | 12:18 PM
  #64
Y2KevSE's Avatar
One of the error codes might be MAP sensor related. Adam (The New CLIMAX) and I have had this code come up.
My hesitation gives a camshaft position sensor code. The sensor was replaced with a new one, but the code still comes up.
It's fun driving like a mad man.
Old Sep 5, 2001 | 01:38 PM
  #65
Y2KevSE's Avatar
I have to agree with you that it's deceivingly fast. On the freeway, I can hit 3 psi with a light tap on the accelerator. I can't imagine how driving's going to be in wet weather.
The metal covers are fun to play on. Hehehehe
Old Sep 5, 2001 | 02:06 PM
  #66
Y2KevSE's Avatar
You should be running the 2.67" hehehehehe
Sound like you're having a blast with the SC (so am I). WOT around the corners in wet weather?!?!?
Old Sep 5, 2001 | 02:14 PM
  #67
UMD_MaxSE's Avatar
Got Bent?
I NEED BOOST!!@#*&^#*@%^#*&@#
Old Sep 5, 2001 | 03:34 PM
  #68
Y2KevSE's Avatar
Wwwwwwwwweeeeeeeeeeee!!!!!!!!!!!!!!!!!!
Old Sep 5, 2001 | 05:32 PM
  #69
UMD_MaxSE's Avatar
Got Bent?
hogan, any more preliminary info on your powerdyne SC?
Old Sep 7, 2001 | 10:37 AM
  #70
Jer's Avatar
Jer
Re: 3.125
Holy crap!! 3.125" pulley??? 3" pulley? Exactly how much torture can these vortechs take? I'd imagine you're pulling about 15-16000rpm out of the thing with a 3.125" pulley.. what are these superchargers rated for?
I'd imagine you'd be spitting supercharger oil in a few thousand K....
Originally posted by delio
Steve,
I am running the 3.125 pulley right now. I have a vacuum leak somewhere I am sure... And with the aftercooler I am still not sure what kind of boost I am pushing... I will be doing more tweaking this weekend. And trying to figure why I keep stalling. Lucky me
Hey Steve...I have a ? for you. Since the AFC has been proven not to work with our cars long term what do you have to say about your Fields Fuel Controller? Do you have to keep re-programing it ir does it work pretty well? It is either that or the PROgram for me. I know you are not a big endorser of that route. Let me know dude. If you want you can take it to e-mail.
Old Sep 7, 2001 | 11:10 AM
  #71
Y2KevSE's Avatar
Re: Re: 3.125
The SC's can take quite a bit. Check out their website for more info. I start boosting a little before 2K rpm (not sure of the exact number because I haven't launched hard yet).
Old Sep 7, 2001 | 12:11 PM
  #72
Y2KevSE's Avatar
Re: Re: Re: Re: 3.125
LOL screw the S/C abuse at 15,000rpm+....what about the Tranny....reminds me...Kev, when you do gas it like you hate it....video tape it...
Yup, trannies going to die first unless it was rebuilt with Level 10 stuff. You want me to tape my tranny blowing up? I'll do that when I get a chance, but it's pretty hard doing it one handed... and Jane hates it when I shoot runs.
  #73
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: 3.125
LAUNCH IT.. LAUNCH IT
Old Sep 7, 2001 | 12:22 PM
  #74
Y2KevSE's Avatar
*BOOOOOOOOM*
Old Sep 7, 2001 | 01:08 PM
  #75
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: 3.125
HELL YEAH~!
-Something about carnage that brings men together ?
Carnage is nice but I don't want my car to go *BOOOOOOM*
Old Sep 7, 2001 | 02:04 PM
  #76
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: 3.125
Like My tranny and Maxima97GLE's tranny.....LoL
-Peace
Why didn't you get an I30t/Canadian SE tranny? Or did you?
Old Sep 7, 2001 | 05:08 PM
  #77
UMD_MaxSE's Avatar
Got Bent?
Hogan, if you get your SC project up and running well, don't be surprised if you see me roll up to your shop with my maxima next year
Old Sep 7, 2001 | 10:45 PM
  #78
Re: Re: Re: 3.125
I hope everything works out that I can have a basic 6psi kit out by Spring '02.
-Peace
Bingo, that is exactly what i wanted to hear. If everything works out, i will be waiting in line to buy it. By the way how much can you get a tomei A/F ratio gauge for?. thanks and best of luck.
Old Sep 8, 2001 | 06:25 AM
  #79
NickStam's Avatar
do you have a backup car when the tranny blows up (hide jane)
Old Sep 8, 2001 | 10:28 AM
  #80
Y2KevSE's Avatar
