Anyone have a write up on.....
I just got a hayden Transmission cooler. Actually its at the UPS office but I was wondering how to install one. Anyone know where I can find a write on this for the max. Anyone have pics on the install. I plan to take pics while I am installing to help others. Thanks in advance for your time guys.
I found it Kev. Thanks for the info
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Xmission%20Cooler.htm
Originally posted by Jane97SE
If he were awake, he would say...You're welcome.
The install wasn't too hard, but the most complicated part is getting your hands in positions you never thought possible. You'll probably need about extra 1 quart.
Cool, i thought i would need 11 quarts. So I don't need to drain fluid just catch it? And that one guy forgot his name used extra transmission hose, so did
you do the same and do you mount yours with zip ties? Thanks
Cool, i thought i would need 11 quarts. So I don't need to drain fluid just catch it? And that one guy forgot his name used extra transmission hose, so didi you do the same and do you mount yours with zip ties? Thanks
Originally posted by mingo
sorry this isnt' kevin.. but it's advisable to use new transmission hose over stock for optimal performance because of the better flow.
...and it is advisable to either get a hose with a greater diameter and then feed the hoses through where it may contact with metal to prevent the hose from rubbing through, or you can slice open an extra peice of tranny oil line and open it up.. i hope this helped a bit
So it's better to use a new transmission hose than the one that came with the 404 cooler.
oops sorry for the confusion, but what i meant to say was, it is alot better to use the "new" transmission fluid lines in place of your stock return and feed line. i didn't replace the feed line or return (forgot which one) but it still works. the reason why i said go with a new one is because the hose in the kit wil probably not be enough to replace both lines and do the plumbing for your new cooler at the same time, so you might need extra.. remember to not "center" the cooler because that big metal thing on the middle of the car will block air flow, so i recomend you mount the cooler to the left of the radiator (still on the radiator but just left portion of it) when you're facing the car. .or which ever way is easy for you. That way you get better air flow through that cooler also creating better cooling effects.
Can heating insulation material be used or ot it better to put a hose around the main hose or hoses that are cappable of coming in contact with heat
in order to check which is the return and feed line, you might want two people to do this.. first you remove one line.. put a oil drain pain under it to catch fluids.. have someone start the car real quick and see if fluids are shooting out of it.. if it shoots out, it's the feed line. if it doesn't it's the return line.. sound scary but it'll be fine. just make sure you shut off the engine instantly after you see fluids gushing out..
This way: M or ->
-> meaning should the cooler be mounted with the part where the hose hooks up to the cooler going downwards or side ways. And which way sideways <-- or -->. oh and the zip ties go right thru the ac condensor without a problem right? I will have to read the instructions again cause i am confused what the other hose insert is for but i will figure it out. Thanks Mingo for the help and did you get your stereo mods?
I'm feeling a little more confident about the install. So what is the best way to have it mounted:
This way: M or ->
This way: M or ->
oh as far as my stereo.. i got all the parts in.. i'm slowly designing my presentation for the system.. going to take alot of restless hours, but it'll or it should be well worth it.. i hope to get it up by the 20th.. (not including upolstry of certain panels)
and hopefully finalized in 3months.. (assuming i get a job by then to buy other accories such as neon lights, sound deadener, electric actuators, digital signal processors, and stuff.. but i'll take it one step at a time.. tahnx for asking thouhg.. g'luck on your install..
daniel
Originally posted by Y2KevSE
Oooooo..... lots of useful information.
Good luck with the install!
Jane hasn't raced me (boost vs. boost) because she's scared. Hehehehe
Thanks to Mingo for all of his knowledge and advice. He explain things so clearly, and answered questions that i had after reading the write-up and cooler instructions. Thanks Mingo.
thank you for your kind words.. now i'm all embarassed.
or this link: http://tinyurl.com/ro7sb
Hi,
I'm also thinking of putting a transmission cooler and oil cooler as well. I'm looking at different types of coolers. Hayden model 404 is about $50, the price for Stillen's cooler is not even listed. I'm gona call tomorrow and see how much it is. Also there is one shop here in houston, that will build me one custom made for $400. What other brands of cooler are ther for 5.5Gen Maxima?
I'm trying to figure out who make a better quality cooler. I don't mind paying a little more for a better product.
By any chance anyone has the Stillen transmission cooler? if so how much are they??
Thanks,
Thanks,
Quoted from a web page
"Description
B&M's SuperCooler low pressure drop coolers reduce the risk of lube system failure. A controlled amount of ATF is allowed to bypass the stacked plate core, passing through a self-regulating orifice which monitors resistance to flow. Controlled by viscosity, the thicker ATF is returned directly to lube through two open bypass openings in the stacked plate core. As operating temperatures increase, more of the ATF flow is directed through the core. Resulting in a highly efficient cooling technology that combines improved protection against lube system failure with the required levels of optimal heat transfer.
Key features
the smallest size & lightest wieght cooler relative to cooling capacity you can buy.
Better cooling than ordinary fin & tube coolers.
Rigid stacked plate design resistant to damage from clying rocks or other debris.
Pressure tested to 200 PSI.
Low pressure drop feature included on #70255, #70268, & #70264.
Includes installation kit.
Applications
70255 SuperCooler 16,000 GVW 11"x5-3/4"x3/4"
70268 SuperCooler 19,000 GVW 11"x7-1/2"x3/4"
70264 SuperCooler 24,000 GVW 11"x6"x1-1/2"
70266* SuperCooler 28,000 GVW 11"x8"x1-1/2"
70273* SuperCooler 15,000 BTU 11"x5-3/4"x1-1/2" (new size)
70274* SuperCooler 29,200 BTU 11"x11"x1-1/2" (new size)
*Racing model doesn't include installation components and has female 1/2 NPT fittings. Can also be used as an engine oil coolers. Note: GVW stands for Gross Vehicle Weight (total weight of vehicle including trailers or towed vehicles)."
"Description
Key features
Applications
i don't see why complicate such simple thing as a tranny cooler. most of the time the atf is REALLY hot, the tranny itself gets hot, well, everything under the hood is not freezing, so unless a tranny cooler is of size of the cooling system radiator, i say in reality it will not do any miracles. What meant to say is the more cooling capability the better.
umnitza
09-01-2015 01:03 PM
